By buying this product you get 204 loyalty points
Digital Interface I2S USB SPDIF 24bit 768kHz DSD512
Musician offers with the Phoenix a high-end digital interface, a real concentrate of technology aimed at providing an extremely clean and stable transmission of the audio signal. Practical, it has a complete range of connectors that will meet most needs, to adapt to the vast majority of audio systems. Moreover, it supports high definition audio streams, for the most accurate and transparent sound reproduction possible.
The USB-B input of the Phoenix is associated with a proprietary high-end USB interface, with an audio solution based on a proprietary MCU+FPU STM32F446 chip. This supports high-resolution audio streams, allowing playback of PCM files up to 24bit 768kHz and DSD512.
The Musician Phoenix conceals a high performance Altera Cyclone IV EP4CE22 FPGA at its heart. It is responsible for processing and redistributing data signals to the various audio circuits, while ensuring a very low level of distortion.
The digital signal of the Phoenix is fully isolated using a high speed 50Mbps optical coupler. This technology significantly reduces the noise level and thus achieves an excellent signal to noise ratio.
The Musician Phoenix clock system uses two constant temperature OCXO (Oven Controlled Crystal Oscillator) SC Cut oscillators, offering extremely low noise. This type of oscillator uses a thermostatic bath to maintain the temperature of the quartz resonator at a fixed temperature and thus minimize frequency variations of the oscillator output.
The power supply stage of the Musician Phoenix benefits from the same care given to the audio circuits, in order to provide them with a clean and stable electrical signal. It includes an O-Type transformer made of high quality monocrystalline copper wire.
The Musician Phoenix offers a particularly complete connectivity, both in input and output, which will adapt to most needs. Thus, the device offers USB-B, AES/EBU, coaxial, optical Toslink and two inputs for external clock. For the outputs, the Phoenix offers AES/EBU, I2S via HDMI and RJ45 as well as Toslink optical and coaxial.
1 | USB Input selection |
2 | AES Input selection |
3 | Settings button |
4 | Optical input selection |
5 | Coaxial input selection |
6 | OK Button |
7 | AES/EBU Output |
8 | I2S RJ45 Output - LVCMOS Standard |
9 | Coaxial output |
10 | Coaxial input |
11 | AES/EBU Input |
12 | I2S HDMI Output - LVDS Standard |
13 | Optical Toslink output |
14 | Clock inputs |
15 | Optical Toslink input |
16 | USB-B Input |
17 | Power connector |
Product type | Digital interface |
Inputs | 1x USB-B 1x Optical Toslink 1x AES/EBU 1x Coaxial 1x 45.1548MHz clock input 1x 49.152MHz clock input |
Outputs | 2x AES/EBU 1x I2S LVDS (HDMI) 1x I2S LVCMOS (RJ45) 1x Optical Toslink 1x Coaxial |
Supported sampling rates | USB : PCM up to 24bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD64 I2S : PCM up to 24bit 384kHz, DSD Natif up to DSD512, DSD DoP up to DSD64 AES / Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
Supply voltage | 100-240VAC, 50/60Hz |
Consumption | ≤ 20W |
Dimensions | 345 x 250 x 85mm |
Net weight | 5.5kg |
Color | Black |
Input | SPDIF |
Input | BNC |
Input | USB |
Input | Optical |
Input | AES/EBU |
Output | AES/EBU |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Output | I2S LVCMOS via RJ45 |
Output | I2S LVDS via HDMI |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Black |
Interface chip | NC |
