Interface reconnue automatiquement par Windows 11, je n'ai pas eu besoin d'installer un driver. Je ne ressens pas de latence entre le flux audio et vidéo géré par le PC.
This product has been replaced by this reference, the PHIREE U2S 2019 USB to SPDIF interface.
Interface USB vers SPDIF SA9023 24bit 96kHz Argent
The Phiree U2SX is a simple, efficient and compact USB to SPDIF and Optical to USB interface. It is based on a Bravo SA9023 chip, supporting sampling rates up to 24bit 96kHz. It also allows AC3 and DTS ES signals to pass through (to another multi-channel decoder).
On this U2SX there is therefore a Micro USB port and a Toslink Optics at the input and a Coaxial connector and a Toslink Optics at the output. The interface allows you to enter Micro USB for Optical or Coaxial output, or to enter Optical to exit Micro USB. All this is integrated into a robust but compact aluminium housing with soft curves.
The Phiree U2S interface is OTG compatible and can therefore be used with smartphones that are also OTG compatible.
| Specifications | |
| Product type | USB Interface |
| Inputs | 1x Micro USB 1x Optical Toslink |
| Output | 1x SPDIF Coaxial 1x Optical Toslink |
| Sampling rate | Up to 24bit 96kHz |
| General | |
| Case material | Aluminium |
| Dimensions | 45 x 64 x 21mm |
| Weight | 50g |
| Color | Argent |
| Package | 1x Phiree U2SX Interface 1x USB-A to Micro USB cable |
| Input | USB |
| Input | Optical |
| Output | Coaxial SPDIF |
| Output | Optical Toslink |
| Max sampling rate | 96kHz |
| Color | Silver |
| Interface chip | SA9023 |
Average votes 4.6 / 5 11 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Nicolas J.
yves G.
Olivier S.
Emile C.
Bruno P.
