Balanced Digital / Analog USB Interface ADC 192kHz
Four years ago now, the Babyface Pro once again demonstrated RME's absolute commitment to top quality work, not only in audio circuitry and driver development, but also in mechanics. Created with the utmost precision from a block of Aluminium, this high-end portable interface incorporated newly designed analogue and digital circuits. Its innovative power-saving technologies achieved supreme fidelity without compromising on level, noise or distortion.
RME returns with an improved version of this USB interface, the Babyface Pro FS. This one benefits from the following features in particular:
The two headphone outputs, with TRS and Mini Jack connectors in parallel, have independent amplification stages to adapt perfectly to low and high impedance headphones, guaranteeing a precise and pure reproduction, whatever the headphones used.
The 3.5mm TRS jack headphone outputs are capable of delivering 90mW of power. The THD of each headphone output has been improved by 10dB and each uses the same AOPs as the ADI-2 Pro. The output impedance of the 3.5mm TRS jack has been lowered from 2 Ohm to 0.1 Ohm.
For the main inputs/outputs, RME has designed XLR connectors that integrate seamlessly into the housing while saving space.
Two digitally controlled preamplifiers provide individually switchable 48V phantom power. These circuits have a 76dB gain range, adjustable in 1dB steps, including a relay controlled PAD, resulting in excellent EIN (Equivalent Noise Level) and overload protection, while providing sufficient gain even for microphones with low levels.
The incredibly efficient design of the Babyface Pro means you never need external power. The interface is perfectly stable when powered via USB 3 and even via most USB 2 ports, with no degradation in technical specifications. This feature makes it an ideal interface for recording anywhere, including with condenser microphones.
This extensive feature set is complemented by a Toslink Optical I/O, which can be used as an ADAT port with SMUX support or as an SPDIF connector supporting sample rates up to 192kHz. Combined with an external ADAT converter (not included), the Babyface Pro supports 12 analog inputs and 12 outputs, ideal for live performances or multi-track studio recordings. You can connect any instrument, line or high impedance, thanks to the Jack 3 and 4 inputs. This makes it possible, for example, to simply record a guitar on the fly without any additional hardware. A MIDI input/output is also available via an included breakout cable, completing the many functions offered by the Babyface Pro.
In digital audio, the clock frequency is an essential factor, creating a correlation between the audio bits and the time reference. Unfortunately, the clock frequency is not always as stable as desired. The Babyface Pro FS thus embeds a SteadyClock FS circuit identical to that of the ADI-2 Pro FS, and allowing to reach an extremely low jitter level, and a very good resistance to it. These excellent performances in all clock modes and the high quality analog conversion allow you to hear your mix as it really is. RME products are converted to digital format without loss or degradation, and the SteadyClock FS provides a very transparent and rich sound reproduction. This allows you to optimize your recordings and mixes, due to the greater depth and clarity of the sound scene.
Like all the latest RME interfaces, the Babyface Pro FS integrates the powerful real-time digital mixer TotalMix FX. It allows a complete and independent routing and mixing from the inputs and playback channels to all physical outputs. Stereo sub-mixes and an understandable Control Room section provide unparalleled monitoring capabilities as well as great routing flexibility.
The Babyface Pro is supplied with the RME TotalMix FX software, available for Windows, Mac OS X and iOS. This incredibly versatile software allows you to use the Babyface Pro in any situation. For example, mixing your guitar with vocals to headphones has never been easier. The FPGA-based mixing DSP adds an extremely flexible 3-band parametric EQ to all inputs and outputs. Reverb and Delay effects are also available.
In addition, the latest RME software, TotalMix Remote, offers remote control of the Babyface Pro FS via iOS, PC or Mac. Through a simple configuration process - simply enter the IP address of the computer you wish to control with TotalMix Remote - you can quickly set any TotalMix FX parameter on a host system from anywhere in your studio or even from a control room outside.
The latest generation of low latency AD/DA converter combined with the unique SteadyClock FS RME technology ensures excellent specifications that will satisfy the most demanding professionals. Add to this the Babyface Pro's many features, excellent sound performance and intuitive control and you have the most understandable and versatile compact audio interface ever created.
The reference design of the Babyface Pro FS leaves nothing to chance. RME devices are designed to keep the audio signal as it really is. They are therefore transmitted in their entirety, nothing is added, nothing is removed. For the Babyface Pro, the audio circuits have been improved to adapt even to the highest gain levels with the best possible dynamic range. The user interface is clearly presented and offers a lot of information. It makes access to every function and configuration mode intuitive and easy to use.
As part of RME's product philosophy, the brand is always developing and optimizing their core technology. RME pioneered multi-channel audio and was the first to offer professional performance on a USB 2.0 interface. RME pays great attention to the development of reliable, stable and regularly updated drivers, while focusing relentlessly on audio quality.
And since RME Audio develops the core of its interfaces, they do not depend in any way on third party structures for improvements, modifications and bug fixes. So you can always benefit from the latest operating system.
" RME sets the performance bar at "very competent" and easily meets that with Babyface Pro FS. Overall, I am happy to recommend the RME Babyface Pro FS. "
| Specifications | |
| Product type | Digital interface |
| Inputs | Balanced XLR Single-ended Jack 6.35mm Optical ADAT / SPDIF |
| Outputs | Balanced XLR Single-ended Jack 6.35mm Single-ended Jack 3.5mm Optical ADAT / SPDIF |
| Inputs/Outputs | USB-B MIDI DIN 5 pins |
| Phantom power supply | 2x 48V |
| AD : Microphone / Line 1-2 | |
| Input | XLR (electronically balanced) |
| Balanced input impedance | 2K Ohm 5.2K Ohm with PAD |
| Single ended input impedance | 1K Ohm 2.6K Ohm with PAD |
| SNR | 113.7dB RMS (unweighted) 117dBA |
| Frequency response | 18Hz - 20.8kHz @ 44.1kHz, -0.1dB 7Hz - 45.8kHz @ 96kHz, -0.5dB 5Hz - 88kHz @ 192kHz, -1dB |
| With PAD active | -0.1dB 8Hz -0.5dB < 4Hz -1dB < 3Hz |
| THD | < -112dB, < 0.00024% < -115dB, < 0.00016% @ 30dB Gain |
| THD+N | < -108dB, < 0.00035% < -100dB, < 0.001% @ 30dB Gain |
| Channel separation | > 110dB |
| Gain range | -11dB to +65dB |
| Max XLR input level | @ 0dB Gain : +8dBu, PAD +19dBu @ 65dB Gain : -57dBu, PAD -46dBu |
| AD : Line/ Instrument Input 3-4 | |
| Input | Jack 6.35mm TS, single-ended |
| Input impedance | 1M Ohm |
| SNR | 116dB RMS (unweighted) 120dBA |
| Frequency response | 5Hz - 20.8kHz @ 44.1kHz, -0.1dB < 3Hz - 45.8kHz @ 96kHz, -0.5dB < 2Hz - 92kHz @ 192kHz, -1dB |
| Max input level | @ +4dBu, 0dB Gain : +13dBu @ -10dBV, 9dB Gain : -5dBu |
| DA : Line Output 1-2 | |
| Output | Balanced XLR |
| Dynamic range | 115dB RMS (unweighted) 118dBA |
| Frequency response | 0Hz - 20.8kHz @ 44.1kHz, -0.5dB 0Hz - 45kHz @ 96kHz, -0.5dB 0Hz - 89kHz @ 192kHz, -1dB |
| THD | -106dB, 0.0005% |
| THD+N | -102dB, 0.0008% |
| Output impedance | Balanced : 300 Ohm Single-ended : 150 Ohm |
| Output level @ 0dBFS | Balanced : +19/+4 dBu Single-ended : +13/+7 dBu |
| DC @ 0dBFS | Jack 6.35mm 4.8V Jack 3.5mm 2.4V Balanced XLR 9.6V |
| DA : Jack 6.35mm Headphone Output 3-4 | |
| Output | Jack 6.35mm TRS, single-ended |
| SNR | 114.8dB RMS (unweighted) 118dBA |
| Noise level | -101.8dBu |
| Output impedance | 10 Ohm |
| Output level @ 0dBFS, 10K Ohm | +13dBu |
| Max power @ 0.1% THD | 60mW |
| DA : Jack 3.5mm Headphone Output 3-4 | |
| Output | Jack 3.5mm TRS, single-ended |
| SNR | 114dB RMS (unweighted) 117dBA |
| Noise level | -107dBu |
| Output impedance | 0.1 Ohm |
| Output level @ 0dBFS, 10K Ohm | +7dBu |
| Max power @ 0.1% THD | 90mW |
| MIDI | |
| Input/Output | 1x Input/Output via breakout cable with DIN 2x5 pins connectors |
| Galvanic insulation | By optocoupled input |
| Hi-Speed mode | Jitter and response time < 1ms |
| Separate 128 byte FIFO for input and output 25.3 | - |
| Digital | |
| Clocks | Internal ADAT input SPDIF input |
| Jitter suppression of external clocks | > 50dB (2.4kHz) |
| Effective clock jitter influence on AD and DA conversion | Near 0 |
| PLL | Ensures zero dropout, even at more than 100ns jitter |
| Digital Bitclock PLL | For trouble free varispeed ADAT operation |
| Supported sampling rates | 28kHz to 200kHz |
| Digital Input : ADAT Optical | |
| Input | 1x Toslink |
| Standard | 8 Channel 24bit, up to 48kHz |
| Double speed (S/MUX) | 4 Channel 24bit, 96kHz |
| Quad speed (S/MUX4) | 2 Channel 24bit, 192kHz |
| Bitclock PLL | Ensures perfect synchronisation, even in varispeed operation |
| Lock Range | 31.5kHz - 50kHz |
| Jitter suppression | > 50dB (2.4kHz) |
| Digital Input : SPDIF Optical | |
| Input | 1x Optical (according to IEC 60958) |
| Compatibility | Consumer and professional format |
| Lock Range | 27kHz - 200kHz |
| Digital Output : ADAT Optical | |
| Output | 1x Toslink |
| Digital Output : SPDIF Optical | |
| Output | 1x Optical (according to IEC 60958) |
| Sampling rates | 28kHz to 200kHz |
| General | |
| Power supply | Via USB or external power supply |
| Consumption | Idle : 2.8W Typical : 3.7W Max : 5.4W |
| Current | @ USB 5V power supply : 700mA (3.7W) @ 12V external power supply : 313mA (3.7W) |
| Dimensions | 108 x 181 x 35mm |
| Weight | 680g |
| Temperature range | +5°C / +50°C |
| Relative humidity | < 75%, non condensing |
| Input | XLR |
| Input | MIDI |
| Input | Jack 6.35mm |
| Input | Optical |
| Output | XLR |
| Output | MIDI |
| Output | Jack 3.5mm |
| Output | Jack 6.35mm |
| Output | Optical Toslink |
| DAC / ADC Chip | NC |
| Max sampling rate | 192kHz |
| Color | Silver |
| Networking | No |
| Remote Control | No |
| Interface chip | NC |
