SMSL unveils its PO100 2024, a digital interface USB to SPDIF coaxial / optical Toslink. This is based on an XMOS XU316 interface and a CK-02 clock circuit, it supports up to PCM 24bit 192kHz and DSD DoP64. The SMSL PO100 2024 can also decode MQA. Two LED indicators provide quick information on its operating mode. In addition, its form factor makes it easy to transport.
The SMSL PO100 2024's USB-C input is combined with a third-generation XMOS XU-316 interface to support high-resolution streams. It even supports MQA streams.
The SMSL PO100 2024 interface's coaxial and optical Toslink outputs are capable of decoding up to PCM 24bit 192kHz and DSD DoP64.
The clock circuit in the SMSL PO100 2024 interface provides extremely low jitter when processing the audio signal.
Two LED indicators show the current sampling rate.
MQA LED indicator
Sampling rate LED indicator
The form factor of the SMSL PO100 2024 makes it easy to transport and use with a smartphone, for example.
Product type | Digital interface |
USB interface | XMOS XU-316 |
Input | 1x USB-C |
Output | 1x Optical Toslink 1x Coaxial |
USB compatibility | MAC OSX / Windows 10 and + (without driver) |
USB transmission | Asynchronous |
Suppoted sample rates | PCM up to 24bit 192kHz DSD DoP64 MQA |
Power supply | 5V 0.1A |
Dimensions | 45 x 13 x 50mm |
Gross weight | 75g |
Color | Black |
Package | 1x SMSL PO100 2024 1x USB-A to USB-C cable 1x USB-C to USB-C cable |
Input | USB |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Max sampling rate | MQA |
Max sampling rate | DSD64 |
Max sampling rate | 192kHz |
Color | Black |
Interface chip | XMOS XU316 |
