DIY USB DAC Board ES9023 PCM2706 16bit / 44khz
DIY USB DAC 24bit/96kHz ES9023 PCM2706 TCXO 16bit / 48khz
11559
24,90 €tax incl.
20,75 € tax excl.
Available
Shipping date: 23-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
This DAC based on PCM2706 (USB management) and a analog digital converter ESS SABER ES9023 offers a very affordable music solution. Equipped with high-quality passive components anditle = "TCXO clocks" href = "http://www.audiophonics.com/en/components-electronics-clock-c-600.html" target = "_ blank">clock 12Mhz full size, it will suit any DIY project.
This DAC provides analog outputs on XHP connector facilitating soldering forRCA plugs CINCH.
Its installation requires no driver whether on PC LINUX, Windows or MAC-OS. Simply connect the card in USB 1.1 to a computer, Raspberry Pi 3 or Pi 2.
Features:/ Strong>
  • USB 1.1 interface: PCM2706: 16/24 bit and 32kHz, 44.1kHz, 48kHz
  • Digital to analog converter (DAC): Saber ES9023
  • Input: USB-B isochronous
  • Analog Outputs: 3.5 mm jack (headphone impedance 16 to 160ohms)
  • Analog outputs: on 3-pin XHP connector (L = left, R = right, G = ground)
  • No external power required (5V via USB port)
  • Clock full size 12Mhz
  • Product shipped naked (no connectors or operating instructions)
  • USB Mode: Isochrone USB 1.1
  • Direct-out: Without AOP output
  • Dimensions: 94x50x14mm
  • Spacing: 85x41mm
  • Weight: 35g
es9023 pcm2706
ComponentES9023
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
