Want to start a DIY audio project? This category is for you. You will find all our cases, in which to install your components in order to protect them and of course, to create a performing and aesthetic product.
Discover the Galaxy range from HiFi 2000. Models with a very nice design quality, particularly robust and ideal for the integration of DIY audio projects.
Housing & accessory kit to install and give a professional finish to your DIY projects based on the balanced DAC EVO SABRE Audiophonics. 100% aluminum construction.
Here is a switch in stainless steel, 1 pole (3 contacts, 1 with closing, 1 with opening). LED 12 V. Protection class IP 67. Switching capacity 250 V AC / 5 A. Cutting diameter 19 mm. Welding pole. Light blue circle.
This bulkhead pass can be particularly useful for deporting USB-C connectivity as part of a DIY audio project. It consists of a male and a female USB-C connector and benefits from a nice design quality with gold-plated connectors, promoting good conductivity and durability.
This panel mount is ideal for deporting a Micro HDMI connector from a module or SBC within a box while adapting this connector to standard HDMI, much more common. This offset allows you to benefit from a connection directly from outside the housing.
This USB-C male to female bulkhead pass-through allows you to offset the USB output of a device or a DIY module, thus offering many integration possibilities.
This black aluminum chassis is ideal for a wide range of DIY projects. Its relatively compact dimensions allow you to build devices such as Bluetooth receivers, headphone amplifiers, small DACs, power supplies, buffers and more.
This brushed aluminum DIY case lets you cover and protect your modules, such as an amplifier. The front and rear of the case have holes for easy integration of your components (connectors and screen).
This NO type switch has two luminous blue switches, each with two positions. The mounting is snap-in type and is done simply with blade connectors or via a few welds. This switch can be integrated in a wide variety of DIY installations
This NO type switch has two luminous green switches, each with two positions. The mounting is snap-in type and is done simply with blade connectors or via a few welds. This switch can be integrated in a wide variety of DIY installations
This NO type switch has two luminous red switches, each with two positions. The mounting is snap-in type and is done simply with blade connectors via a few welds. This switch can be integrated in a wide variety of DIY installations.
This NO type switch has two luminous yellow switches, each with two positions. The mounting is snap-in type and is done simply with blade connectors or via a few welds. This switch can be integrated in a wide variety of DIY installations
This connector is compatible with Ø19mm push buttons and monostable/bistable switch. It allows to quickly mount a button / switch without soldering or screwing anything. This connector has 7 x 15 cm wires and is suitable for the majority of switches with RGB LED.
This partition pass socket integrates two USB-A 3.0 connectors with a 90° angle. The USB 3.0 version can be very useful for your DIY mounts in a box in order to take advantage of an easy-to-install USB connector offset, and also ensures a high signal transmission rate.
Here's an orange aluminum knob for customizing your Fosi Audio V3 amplifier. To replace, simply pull the knob installed on your amplifier off its axis before pressing the replacement button.
This gray thermal paste improves the thermal conductivity between a heating component and an associated radiator in order to improve heat dissipation. It has a density of 2.5G/Cc and a thermal conductivity of 6.8W/M-K.
This gray thermal paste in syringe form improves the thermal conductivity between a heating component and an associated radiator in order to improve heat dissipation. It has a density of 2.3G/Cc and a thermal conductivity of 4.8W/M-K. It can withstand temperatures from -50°C to 200°C.
