This very small module eliminates common ground noise from an audio system. Operating at 12V, it is particularly well suited for Car Audio use. If its installation between the source and the amplifier is extremely simple, the noise reduction provided is important and will allow you to improve the reproduction of your audio system.
Isolator Noise Attenuation Module
Ce module ne permet qu'une isolation du bruit ayant pour origine la masse commune.
Spécifications | ||
Type de produit | Module d'isolation | |
Entrée | 1x Jack 3.5mm | |
Sortie | 1x Jack 3.5mm |
Général | ||
Alimentation | 9-13VDC via Jack DC 3.5/1.35mm (Alimentation non fournie) | |
Dimensions | 55 x 15.3mm |
