I2S / USB to AES/EBU / Coaxial / Optical / HDMI Digital Interface 32bit 384kHz DSD128
This module will allow you to combine an Amanero or XMOS USB interface (sold separately) to enjoy a complete and versatile digital interface.
Reference : 13627
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 12-11-2026.
Digital interface
Interface Digitale I2S / SPDIF / AES vers I2S / USB avec Emplacement pour Interface Amanero / XMOS
This module will allow you to combine an Amanero or XMOS USB interface (sold separately) to enjoy a complete and versatile digital interface. You will therefore have an I2S or USB input (input selection via a jumper) as well as a complete panel of outputs with HDMI, Coaxial S/PDIF, Toslink Optics and AES/EBU. The interface supports sampling rates up to 32bit 384kHz and DSD128 via the HDMI output. The Coaxial and XLR outputs are galvanically isolated to significantly reduce noise.
The USB Amanero / XMOS interface is sold separately.
Note: Does not support I2S modules without Master Clock (MCLK) such as the Raspberry Pi. Supports the conversion of I2S signals via modules with MCLK, BCLK, LRCK, DATA.
Note: For 32bit 384kHz or DSD64/128 files to be supported via HDMI, it is necessary to use a low level input.
J5 connector location
This module must be supplied with 5V via its J5 connector.
Product typeDigital interface
ChipWM8805
InputsUSB (USB Interface sold separately) OR I2S
Outputs1x HDMI
1x Optical Toslink
1x Coaxial S/PDIF
1x AES/EBU
Compatible USB interfaceAmanero
XMOS
I2S / HDMI CompatibilityAudio-GD / PS Audio
Supported sampling rateCoaxial, AES/EBU : up to 24bit 192kHz
Optical : up to 24bit 48kHz
HDMI : up to  32bit 384kHz / DSD128
Power supply5V DV via J5 connector
Dimensions100 x 73.5 x 26.5mm
Fixation holes spacing90 x 64mm
HDMI Pinout compatible with Audio-GD / PS Audio
Interface Digitale I2S / USB vers AES/EBU / Coaxial / Optique / HDMI 32bit 384kHz DSD128
InputI2S
OutputHDMI
OutputOptical Toslink
OutputCoaxial SPDIF
Max sampling rateDSD128
Max sampling rate384kHz
Interface chipWM8805
