USB to I2S Interface Board SA9227A 32bit 384kHz DSD128
This small USB to I2S interface module will allow you to integrate a USB input with good performance into a DIY audio project. It is based on an SA9227A chip, supporting PCM audio streams up to 32bit 384kHz and DSD up to DSD128.
Reference : 16719
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 17-09-2026.
USB Interface Board
USB to I2S SA9227A 32bit 384kHz DSD128
Module Interface USB vers I2S SA9227A 32bit 384kHz DSD128
This small USB to I2S interface module will allow you to integrate a USB input with good performance into a DIY audio project. It is based on an SA9227A chip, supporting PCM audio streams up to 32bit 384kHz and DSD up to DSD128. The module is also equipped with three low-noise LDOs and filter capacitors, providing the audio circuits with a clean and stable power supply. Two SiTime clocks are also used to ensure low jitter, as well as a CMOS buffer to isolate the I2S signal.
Product typeUSB to I2S interface board
USB interface chipSA9227A
Input1x USB-B
OutputI2S on solder pads
DSD up to DSD128
Supply voltage5V via USB
PCB dimensions (without connector)30 x 69mm
Mounting holes spacing25.5 x 64mm
OutputI2S
Max sampling rate384kHz
Max sampling rateDSD128
Interface chipSA9227
This small USB to I2S interface module will allow you to integrate a USB input with good performance into a DIY audio project. It is based on an...
