File Reader Module USB SD Bluetooth 5.0
45%
This small file player module has various inputs. It provides a USB-A port, a Micro SD slot, an auxiliary input on 3.5mm jack as well as a Bluetooth 5.0 connectivity allowing you to broadcast your music remotely. An LED display shows the volume level or the selected input. The control is done simply using the buttons on the front panel or via the remote control provided.
Reduced price!
Reference : 15904
Limited time offer:
7,90 €tax incl.
-45%
4,35 €tax incl.
3,62 € tax excl.
Last items in stock !
Shipping date: 01-05-2026.
File reader
Lecteur de fichier USB SD Bluetooth 5.0
BUTTON FUNCTIONS
ButtonBluetoothUSBAUXRadio
MODEUSB ➞ SD ➞ Bluetooth ➞ AUX ➞ Radio
VOL-Short press : previous track
Long press : volume -
Long press : volume -Short press : previous station
VOL+Short press : next track
Long press : volume +
Long press : volume +Short press : next station
SCANPlay / PausePlay / PauseShort press : MuteShort press : Mute
Long press : automatic scan
Fonctions de la télécommande
Power ButtonOn / Off
Stop Button/Stop//
Mute ButtonMute
Mode ButtonUSB ➞ SD ➞ Bluetooth ➞ AUX ➞ Radio
Play mode Button/Loop//
EQ ButtonSound EQ
Previous Buttonprevious trackShort press : previous track
Long press : rewin
/Short press : previous station
Long press : search previous station
Next ButtonNext trackShort press : next track
Long press : fast forward
/Short press : next station
Long press : search next station
Play/Pause ButtonPlay/PausePlay/PauseMuteMute
Volume- ButtonVolume -
Volume+ ButtonVolume +
0~9 Buttons/Select track/Select station or frequency
Product typeFile reader
InputsBluetooth
1x USB-A
1x Micro SD slot
Output amplitude> 600mV
Supply voltage9V to 12V DC
Dimensions91.5 x 41mm
Mouting holes spacing80 x 28mm
This small file player module has various inputs. It provides a USB-A port, a Micro SD slot, an auxiliary input on 3.5mm jack as well as a...
