By buying this product you get 74 loyalty points
USB Audio Processor 24bit / 48kHz 10 to 10 channels
The miniDSP 10x10 HD performs both the functions of multi-way crossover, audio processor, mixer source and converter for analog and digital audio sources. It will delight audiophiles who want a centralized system for both an Audio / Video 2.1 / 5.1 / 7.1 channels source and a digital source (stereo) to a single amplification & speaker system.
To do this, the device has large connectivity (2 digital inputs / 2 digital outputs / 8 analog inputs / 8 balanced and unbalanced analog outputs) and an ADC / DAC CS42528 24bit - 48 / 96kHz with a SNR of 114dB.
The DSP engine configuration is made easy with miniDSP real-time GUI. The latter only requires a USB connection to a computer for initial configuration, and can run then standalone thanks to rotary controller on the front or an IR remote control.
The device is protected by a steel housing with aluminum front for aesthetics and strength. It comes with rack-mounting brackets (removable for a strictly domestic use).
To make the most of your miniDSP you have to use a plug-in.
When receiving your order, you will find in the package a document explaining the method to get your free plug-in.
here you may find a tutorial to make your first steps wioth digital audio correction via miniDSP graphical user interface.
Thanks to its remote learning function, this Audio miniDSP processor is compatible with a wide range of IR remote control.
We recommend this model of IR remote which supports 38 Khz NEC (works with virtually with all miniDSP devices and even with streamer based on RPI)
| Specifications | |
| Type | Audio processor |
| DSP | 28 / 56bit |
| ADC / DAC | CS42528 24bit 114dB SNR |
| Sampling frequency | 48 / 96kHz |
| Connectors | Digital (2 x IN, 2xOUT SPDIF / Toslink / AES-EBU) Analog (8 x IN, symmetric and asymmetric 8xOUT) |
| Control | rotary encoder Remote control Rich configuration via miniDSP interface (windows, mac) |
| CE / FCC - RoHS Compliant | Yes |
| Package Contents | |
| Universal power supply 12VDC | x1 |
| Armored USB Cable 1.5m | x1 |
| Toslink cable | x1 |
| Input | Optical |
| Input | AES/EBU |
| Input | SPDIF |
| Input | Screw terminals |
| Input | RCA |
| Output | AES/EBU |
| Output | RCA |
| Output | Screw terminals |
| Output | Optical Toslink |
| Output | Coaxial SPDIF |
| Max sampling rate | 48kHz |
| Color | Black |
