MiniDSP DDRC-22D 24/96kHz Stereo Digital Dirac Live with UMIK-1
By buying this product you get 88 loyalty points
Reference : 9040
889,00 €tax incl.
740,83 € tax excl.
MiniDSP DDRC-22D
DSP Stereo Numérique Dirac Live 24bit 96kHz avec UMIK-1
MiniDSP DDRC-22D DSP Stéréo Numérique Dirac Live 24bit 96kHz avec UMIK-1
The DSP DDRC-22D fits between your digital source and your integrated preamplifier/amplifier, or even between two digital sources. It has been designed to radically transform your listening experience and allow you to rediscover your favorite audio installation and songs. MiniDSP and Dirac Live bring you here a solution for acoustic processing and digital correction with this unique combination of hardware and software.
The processor incorporates a sophisticated digital processing algorithm that intelligently corrects frequency and time errors caused not only by the listening room but also by the people in it. The result is an improved stereo image, greater clarity and realism, more accurate timbre and deeper bass. In short, the DDRC-22D is the product you need to correct the acoustics of your listening room, while enjoying an ergonomic and easy-to-use interface.
The case consists of a high-resolution 24bit 96kHz audio processor. It is accompanied by a UMIK-1 measuring microphone with its own calibration system, to obtain excellent results. The DDRC-22D can also be associated with this infrared remote control.
Product typeDSP with measuring microphone
Input / Output resolution24bit
Internal sampling rate96kHz
Output sampling rate96kHz
CompatibilityWindows : Vista SP1, XP Pro SP2, Win7, Win8
MAC OS
Minimum recommanded configuration : Intel Pentium III or AMD Athlon XP (SSE needed), 2Go RAM, 2 USB-A port
Dimensions210 x 205 x 40mm
Weight3.2kg
Package1x MiniDSP DDRC-22D
1x USB-A to USB-B Cable
2x Optical cable
1x Tripod stand
1x UMIK-1
1x 5V 2A Power supply
2x Mounting brackets
Connection diagram
SOFTWARE MODELING OF SOUND RECORDING FOR ACOUSTIC PROCESSING
BEFORE / AFTER Response curve
DIRAC LIVE SPECTRUM CORRECTION SOFTWARE INTERFACE
InputXLR
OutputCoaxial SPDIF
OutputOptical Toslink
Max sampling rate96kHz
Superbe outil de correction
c'est un peu galère pour recuperer le soft mais après l'utilisation est hyper simple.
Sur mon système il n'y avait pas de grosses corrections mais la zone d'ecoute est bien élargie et la stéréo est propre pour les 3 places du canapé. A voir ce que cela pourrait donner en situation plus cahotique. Trouver impérativement une vielle télécommande IR pour le pilotage de tous les jours et la comparaison Avec/Sans.
This review has been posted for MiniDSP DDRC-22D 24/96kHz Stereo Digital Dirac Live with UMIK-1
