MINIDSP DDRC-24 Interface DAC DSP Processor SHARC ADSP21489 Dirac Live
The MiniDSP DDRC-24 is the most compact Dirac Live and DAC processor in the range, allowing you to enjoy the excellent acoustic correction solution without the hassle of a large device.
Reference : 14310
469,00 €tax incl.
390,83 € tax excl.
Shipping date: 30-09-2025.
MiniDSP DDRC-24
MiniDSP DDRC-24 Interface DAC Processeur DSP SHARC ADSP21489 Dirac Live
Powered by a 400MHz Analog Devices SHARC processor, the DDRC-24 features 4 channels of outputs, allowing for example the integration of a subwoofer or stereo system associated with the Dirac Live system. Dirac Live allows access to numerous parameters such as a mixing matrix or crossover filters via an easy to use interface. Inputs include stereo RCA, Toslink Optical, and Mini USB (XMOS), both of which are connected to a DAC that supports PCM sample rates up to 192kHz.
The DDRC-24 comes with a Dirac Live license and can also be used with the Room EQ Wizard software to perform measurements prior to the Dirac calibration if required.
MiniDSP DDRC-24 Interface DAC Processeur DSP SHARC ADSP21489 Dirac Live MiniDSP DDRC-24 Interface DAC Processeur DSP SHARC ADSP21489 Dirac Live MiniDSP DDRC-24 Interface DAC Processeur DSP SHARC ADSP21489 Dirac Live
The UMIK-1 microphone is not supplied with this product. It can be purchased separately (see accessories) to perform acoustic measurements using the Dirac Live software.
Product typeDSP
DSP ChipAnalog Devices SHARC ADSP21489 32bit floating point 400Mhz
Internal processing resolution and sample rate32bit / 48kHz
DAC resolution24bit
Inputs1x Unbalanced stereo RCA
1x Optical Toslink
1x Mini USB (ASRC : 20Hz - 216kHz)
Outputs2x Unbalanced stereo RCA
USB InterfaceXMOS Xcore200
Input levels2Vrms / 4Vrms (switchable)
Output level2Vrms
Input impedance10kΩ
Output impedance560kΩ
Calibration softwarePlugin DDRC-24
Filtering technologyDirac Live
DSP presetsUp to 4 presets
Impulse response correction
Infrared remote learning
CompatibilityWindows
Mac
Bass management
Room EQ Wizard support
Dimensions119 x 107 x 27mm
Power supply12VDC 2.5mm via Jack DC 2.1mm
Case materialAluminium
Package1x MiniDSP DDRC-24
1x Dirac Live license
1x Power supply 12V
1x USB cable
1x Plugin for DSP control
Max sampling rate48kHz
The MiniDSP DDRC-24 is the most compact Dirac Live and DAC processor in the range, allowing you to enjoy the excellent acoustic correction solution...
