MINIDSP FLEX Audio Processor DSP SHARC ADSP21489 XMOS Bluetooth
The miniDSP Flex is the brand's 3rd generation 2-in/4-out audio processor. It keeps the powerful floating point processor used previously with a redesigned input/output architecture to offer versatile connectivity. This version features single-ended RCA stereo inputs and outputs, as well as a full digital input panel with Bluetooth, USB-B, coaxial and Toslink optical.
By buying this product you get 62 loyalty points
Reference : 15884
629,00 €tax incl.
524,17 € tax excl.
miniDSP Flex
miniDSP Flex Processeur Audio DSP Dirac Live SHARC ADSP21489 XMOS Bluetooth
An OLED display on the front panel and a volume controller make it easy to control the unit. Of course, the Flex series incorporates the powerful audio processing features developed by miniDSP: a flexible parametric equalizer, IIR and FIR filters, crossovers, the possibility to program the biquad filter and delay for each output... In addition, all systems can be software enhanced with the Dirac Live® correction solution for fine tuning over the entire frequency range.
The miniDSP Flex offers a wide range of uses and applications, whether in combination with a compact digital stereo preamplifier, for integration with a subwoofer or for active speaker optimization.
The DIRAC licence is not included, but available here.
Test du MiniDSP Flex par Audio Science Review (Amir)
What a nice combination of functionality, usability and performance! As with many DAC companies, it is clearly Minidsp has put strong focus on chasing away sources of noise and distortion. All AV processor and receiver companies lose any excuses they have for not providing this level of performance seeing how the Flex also implements various signal processing modules. "
Product typeDSP
CPUAnalog Devices floating point DSP SHARC ADSP21489 400MHZ
USB InterfaceXMOS
InputsBluetooth
1x USB-B
1x Coaxial
1x Optical Toslink
1x Stereo RCA
Outputs2x Stereo RCA
Supported Bluetooth codecsAAC, SBC, aptX, aptX HD, LDAC
Recording feature via USB4 channel output processing
Processing sampling rate32bit 96kHz
(32bit 48kHz with Dirac Live® license)
Analog input impedance100kΩ
Analog output impedance200Ω
Max input/output levels2Vrms / 2Vrms
Frequency response20Hz-20kHz ±0.1dB
SNR (digital to analog)120dB(A)
THD+N (digital to analog)-110dB (0.0003%) ±3dB
Crosstalk (digital to analog)-120dB
SNR (aanlog to analog)115dB(A)
THD+N (analog to analog)-106dB (0.0005%) +/-3dB
Crosstalk (analog to analog)-115dB
Filterinf technologyFIR + IIR
Dirac Live® optional: 3x full range correction (20~20kHz)
DSP presetsup to 4 profiles
Supply voltage12VDC 1.6A (power adapter included)
Consumption9W
Standby consumption2.5W
Dimensions150 x 180 x 41mm
Package1x miniDSP Flex
1x Remote control
1x Power adapter
Max sampling rate96kHz
4 reviews
Miracle box with a small annoyance
I swapped my miniDSP 2x4 HD for the Flex because of the good results in Audio Scene Review. A direct hit! I was already quite happy with the 2x4 HD, but the Flex is audibly better in terms of dynamic range and SNR. The music sounds even more spacious, precise and clean. The switch was super easy: I just had to update the firmware and PC software, load the preset file from the 2x4 HD and that was it. I can even continue to use my Audiophonics 12V linear power supply. What is annoying, however, and typical for miniDSP, is that the RCA sockets are too close together. This makes cabling tricky, as the plugs touch each other. Thanks to Audiophonics for the super fast delivery.
This review has been posted for MINIDSP FLEX Audio Processor DSP SHARC ADSP21489 XMOS Bluetooth
Très bon DSP
Excellent rapport qualité prix. Utilisé dans une config 2.1. Le jour et la nuit avec mon ancien filtre passif sur le caisson. Sorties analogiques de bonne qualité (genre DAC à 300/500€). Manque juste un trigger 12v pour en faire un produit parfait.
Excellent device
I ordered FLEX with RCA outputs, I must say that it is an excellent device, supported by excellent software, with which it is possible to model the response of the listening room.
Only negative note, the volume knob, too plasticky.
Très bon appareil
J'ai pris ce Flex car je souhaitais faire de l'égalisation sur mes enceintes, et sur casque.
Un peu plus compliqué à installer et à configurer qu'un simple dac.
Je suis resté à l'égalisation manuelle, en m'aidant de mesures au micro et du logiciel REW, sans recourir à Dirac Live.
On pilote le Flex grâce au logiciel fourni, sur PC dans mon cas, ce qui permet d'afficher l'égaliseur paramétrique. Les réglages peuvent être mis en mémoire, et de plus 4 configurations à accès direct. Comme j'ai 2 paires de sorties RCA sur ce modèle, préampli d'un côté et ampli casque de l'autre, avec 2 égalisations différentes, une pour enceintes et l'autre pour un modèle précis de casque que j'avais mesuré avec un MiniDSP EARS. Je bascule simplement par Config1 et Config2 de l'un à l'autre, dans le logiciel PC.
La qualité d'écoute est bien là, comme avec tout bon dac, pour un prix de dac de moyenne gamme.
Ce MiniDSP m'a permis de vraiment optimiser ma chaîne grâce à l'égalisation.
The miniDSP Flex is the brand's 3rd generation 2-in/4-out audio processor. It keeps the powerful floating point processor used previously with...
