MINIDSP FLEX HT DSP Audio Processor
The miniDSP Flex HT is part of the miniDSP Flex range of advanced audio processors. This device is a 2x8-channel, multi-channel DSP processor featuring an HDMI ARC/eARC input. The miniDSP Flex HT features a complete suite of audio processing functions: bass management, parametric equalizers, crossover, advanced biquad programming and delay/gain controls.
By buying this product you get 79 loyalty points
Reference : 18286
799,00 €tax incl.
665,83 € tax excl.
Shipping date: 07-04-2026.
MINIDSP FLEX HT
Audio DSP Processor 2x8 Channels SHARC ADSP21489 XMOS HDMI ARC eARC
MINIDSP FLEX HT Processeur Audio DSP 2x8 Canaux SHARC ADSP21489 XMOS HDMI ARC eARC
With multiple digital inputs and eight unbalanced analog output channels, the miniDSP Flex HT can support active loudspeakers with up to four stereo channels. Flexible 2x8 signal routing allows many other configurations, such as two-way, three-way and multiple subwoofers.
The Flex HT features stereo digital inputs in USB-B, coaxial and Toslink optical formats. The HDMI ARC/eARC and USB inputs support 8 channels of linear PCM. A front-panel OLED display and volume control knob provide easy control of the device. Settings can be easily modified using Stereo Dirac Live® acoustic correction software (DIRAC license not included, but available here).
The analog RCA output stage boasts excellent performance, with a THD+N of just 0.0003%.
This device is the perfect solution for users looking for an audio processor for a home-cinema or multi-channel Hi-Fi installation.
Please note that Flex HT does not support bitstream decoding (e.g. Dolby/DTS). The audio source must be capable of producing linear PCM (LPCM) for multichannel support via HDMI.
MiniDSP FLEX HT rear panel
1HDMI ARC/eARC input
2Power supply connector
3USB-B input
412V Trigger out
5Toslink optical input
6SPDIF coaxial input
78x Unbalanced RCA analog output
Product type2x8 channels DSP
Inputs1x HDMI ARC/eARC (up to 8 LPCM channels)
1x USB-B (up to 8 channels)
1x Coaxial (Stereo)
1x Optical Toslink (Stereo)
Ouputs8x RCA unbalanced
Other connectors12V Trigger
ProcessorAnalog Devices SHARC ADSP21489 400MHz 32bit floating point
USB interfaceXMOS
USB compatibilityWindows (ASIO Driver)
Mac OS
Linux
(Multichannel configuration up to 7.1 channels)
HDMI connectivityARC/eARC (up to 8 LPCM channels)
Supported sample rate : 20-216KHz
Output impedance200Ω
Max. output level2Vrms
Fréquency response20Hz–20kHz (±0.05dB)
SNR (D/A)125dB (A) with DRE
THD+N (D/A)-111 dB (0.0003 %)
Crosstalk (D/A)-120dB
Filtering technologyminiDSP DSP toolbox: routing, bass management, parametric EQ, crossover, gain/delay.
DSP presets4
HDMI CEC
Power supply12V 1.6A
Power consumption4.8W
2.9W (Standby)
Dimensions150 x 180 x 41mm
Package1x miniDSP FLEX HT
1x Remote control
1x Power cable
InputHDMI ARC
Max sampling rate48kHz
Max sampling rate192kHz
Flex HT the audiophile nirvana!
I bought it on December 18, 2024. It arrived in Hungary very quickly. I replaced a Lexicon MV-5 processor. The bass is much more restrained, not so fluid and expansive. The active switching also works very well in it, I use LW-R 24db/octave filters. The crossover frequencies are 100Hz/4KHz. I don't use Parametric EQ for now, maybe when I buy the Umik-1 measurement microphone. It would be nice to buy a Dirac live license for it, but for now it's very expensive for me, almost the price of the device. There are power stages for each speaker, for each speaker, I use these now, all class D: AUDIOPHONICS MPA-S125NC ; Douk Audio TPA3116 ; Wondom TPA3255. I'm going to order these two power amps from Audiophonics now: O-NOORUS D1 Class D Amplifier TPA3255 PFFB. My dream is to get one of these power amps: AUDIOPHONICS HPA-H250NC Power Amplifier 6 Channels NCore NC252MP. This MiniDSP Flex is a real big gun, a game changer, the DAC in it is also very good, this is also confirmed very well by the Audio Science Review. I recommend it to everyone who would like to build a truly audiophile system with active switching. I use 2x3 way speakers with it, each in pairs: Dayton Audio PT2C-8 Planar Tweeter ; Tang Band_W5-2143 Midrange; SICA 12 PF 3 Sub. The fronts are open baffle, and the subs are closed! Thank you Audiophonics!
This review has been posted for MINIDSP FLEX HT Audio DSP Processor 2x8 Channels SHARC ADSP21489 XMOS HDMI ARC eARC
The miniDSP Flex HT is part of the miniDSP Flex range of advanced audio processors. This device is a 2x8-channel,...
