Faut juste ne pas en mettre de trop.
Cordons secteur sans blindage? Un pourtour de ce produit cote recepteur et le tour est joue.
Noise Suppressor Adhesive Tape Pulshut 4m
Oyaide NRF-005T is a noise suppression tape using PULSHUT® (high performance non-woven textile) material developed by Asahi Kasei Corporation. This is a revolutionary material for suppressing electromagnetic noise and radiation generated by AV equipment and cables, allowing for more transparent sound reproduction. It also uses no magnetic elements. With a thickness of only 0.05mm, the NRF-005T offers great flexibility for convenient installation on any surface. It is easy to use, as the NRF-005T is simply snapped onto areas of the audio/video equipment or cable that are likely to produce noise.
Product type | Noise suppressor adhesive tape |
Material | Pulshut® |
Adhesive surface | Acrylic |
Tape width | 15mm |
Tape thickness | ~ 0.11mm (base material: 0.05mm + adhesive: 0.06mm) |
Density | 0.8g/cm³ |
Surface resistance | ≥ 1.0*10^12Ω/cm |
Volume resistivity | ≥ 1.0*10^12Ω/cm |
Tension | 3.5kgf/cm³ |
Operating temperature range | -20°C / +90°C |
Environmental certifications | RoHS REACH Sans halogène |
Quantity | 4m |
Average votes 4.3 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
FRANK D.
laurent C.
Fabrice j.
