Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
freddy w.
bluffé et dubitatif
Bj, j'ai suivi un avis au final d'un ami qui m'a assuré que j'allais tomber parterre en écoutant ce cable...
Françoise B.
Dans un système de qualité, ceux qui sont encore septique sur le traitement du signal numérique ethernet il faut essayer cet...
Patrick P.
Musique !
Trois LP12 et maintenant trois Fosi phono x5.
Ravi, tellement ce petit boîtier fait entendre la musique et les musiciens en...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 11781
    In Stock
    Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the German, French and English references enjoys a very good design quality. They are ideal for parallel RL and RLC "plug" correction in parallel circuit, instead of low quality...
    45,20 € 37,67 €Ex.
    In Stock
  • Ref : 11770
    In Stock
    9,00 € 7,50 €Ex.
    In Stock
  • Ref : 14380
    In Stock
    60,10 € 50,08 €Ex.
    In Stock
  • Ref : 15614
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 15166
    In Stock
    71,50 € 59,58 €Ex.
    In Stock
  • Ref : 11771
    In Stock
    10,40 € 8,67 €Ex.
    In Stock
  • Ref : 11772
    12,20 € 10,17 €Ex.
    In Stock
  • Ref : 11760
    In Stock
    1,50 € 1,25 €Ex.
    In Stock
  • Ref : 11763
    In Stock
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 13740
    In Stock
    Jantzen Audio Cross Cap MKP 400V capacitors are considered to be the best value for money for the design of passive filters for loudspeakers. Of European manufacture, this new competitor to the German, French and English references enjoys a very high quality of design.
    13,80 € 11,50 €Ex.
    In Stock
  • Ref : 11773
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 11764
    In Stock
    2,40 € 2,00 €Ex.
    In Stock
  • Ref : 11765
    In Stock
    2,70 € 2,25 €Ex.
    In Stock
  • Ref : 11774
    In Stock
    16,90 € 14,08 €Ex.
    In Stock
  • Ref : 11775
    In Stock
    18,00 € 15,00 €Ex.
    In Stock
  • Ref : 15563
    In Stock
    21,30 € 17,75 €Ex.
    In Stock
  • Ref : 11776
    In Stock
    23,20 € 19,33 €Ex.
    In Stock
  • Ref : 11766
    In Stock
    3,40 € 2,83 €Ex.
    In Stock
  • Ref : 11777
    In Stock
    25,20 € 21,00 €Ex.
    In Stock
  • Ref : 11767
    In Stock
    4,50 € 3,75 €Ex.
    In Stock
  • Ref : 11778
    In Stock
    29,80 € 24,83 €Ex.
    In Stock
  • Ref : 11768
    In Stock
    4,80 € 4,00 €Ex.
    In Stock
  • Ref : 11779
    In Stock
    32,20 € 26,83 €Ex.
    In Stock
  • Ref : 11769
    In Stock
    5,40 € 4,50 €Ex.
    In Stock
  • Ref : 11780
    In Stock
    37,70 € 31,42 €Ex.
    In Stock
  • Ref : 15459
    In Stock
    Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most other standard electrolytic capacitors.
    1,30 € 1,08 €Ex.
    In Stock
  • Ref : 15480
    In Stock
    4,70 € 3,92 €Ex.
    In Stock
  • Ref : 15468
    In Stock
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 15481
    5,40 € 4,50 €Ex.
    In Stock
  • Ref : 15469
    In Stock
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 15482
    In Stock
    5,50 € 4,58 €Ex.
    In Stock
  • Ref : 15470
    In Stock
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 15471
    In Stock
    2,10 € 1,75 €Ex.
    In Stock
  • Ref : 15458
    In Stock
    1,30 € 1,08 €Ex.
    In Stock
  • Ref : 15460
    In Stock
    1,30 € 1,08 €Ex.
    In Stock
  • Ref : 15461
    In Stock
    1,40 € 1,17 €Ex.
    In Stock
  • Ref : 15483
    In Stock
    6,70 € 5,58 €Ex.
    In Stock
  • Ref : 15472
    In Stock
    2,10 € 1,75 €Ex.
    In Stock
  • Ref : 15484
    In Stock
    9,40 € 7,83 €Ex.
    In Stock
  • Ref : 15473
    In Stock
    2,60 € 2,17 €Ex.
    In Stock
