LHY AUDIO EFI Optical Galvanic Network Isolator Black
LHY Audio's EFI implements complete galvanic isolation through optical conversion, transforming the RJ45 Ethernet signal into fibre optic transmission before reconverting it to copper format at the output. This physical break in the electrical path mechanically eliminates ground loops between source and destination, while the absence of conductive continuity removes common mode noise and electromagnetic interference that can degrade data flow timing.
By buying this product you get 54 loyalty points
Reference : 21373
549,00 €tax incl.
457,50 € tax excl.
Shipping date: 01-12-2026.
LHY Audio EFI Optical Galvanic Network Isolator Black
LHY Audio EFI : Front view
LHY Audio
's EFI
implements complete galvanic isolation through optical conversion, transforming the RJ45 Ethernet signal into fibre optic transmission before reconverting it to copper format at the output. This physical break in the electrical path mechanically eliminates ground loops between source and destination, while the absence of conductive continuity removes common mode noise and electromagnetic interference that can degrade data flow timing. The architecture is based on a linear power supply incorporating the LT3042 ultra-low noise regulator in PNP topology, ensuring stable power supply to the optical conversion circuits without introducing high-frequency parasitic components.
Product typeNetwork isolator
Input1x RJ45 port
Output1x Isolated RJ45 port
Voltage regulatorLT3042
Power supply100V ~ 240V AC
Dimensions150 x 50 x 175mm
Weight1.5kg
Package1x LHY Audio EFI
1x Power cable
3 reviews
Excellent
Dans un système de qualité, ceux qui sont encore septique sur le traitement du signal numérique ethernet il faut essayer cet isolateur optique . Avec de bons cables rj45 ( un rj 45 Audiophile en sortie en remplacement d’un cable fourni) et après on ne peut plus s’en passer.
C’est plus qualitatif et musical que d’acheter un streamer 3 fois plus cher que celui que l’on possède.
Très bien fabriqué ,plug and play, et un grand merci à audiophonics .
This review has been posted for LHY AUDIO EFI Optical Galvanic Network Isolator Black
Fantastique amélioration
Oui, cet isolateur apporte une réelle amélioration… et ce n’est pas un effet placebo. Dans mon cas, il traite le signal ethernet juste avant le streamer Innuos (mini pulse). Il fait des merveilles : haut du spectre moins crispé, médium aéré et basses un peu plus charnues. Et je comprends à présent la notion de silence habité, du fond plus noir. C'est maintenant irréversible, cet isolateur est indispensable dans mon système. Je recommande hautement.
Top produit
Cet avis est bien sûr subjectif.
Amélioration de la clarté, de la dynamique et diminution du bruit.
Matériel sur lequel il est installé : streamer Auralic Aries G2.2, DAC Musician. Pré-ampli Parasound JC2, ampli Audiaflight FLS10 ( utiliser en bloc de puissance), enceintes EgglestonWorks Andra 3 SE.
Frédéric
LHY Audio's EFI implements complete galvanic isolation through optical conversion, transforming the RJ45 Ethernet signal into fibre optic...
