Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Claude G.
Super !!
Remy C.
Simple et efficace
Lacking
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 5701
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. It is therefore possible to achieve better inductances while maintaining low internal impedance and zero...
    8,50 € 7,08 €Ex.
    In Stock
  • Ref : 5706
    In Stock
    10,50 € 8,75 €Ex.
    In Stock
  • Ref : 5708
    In Stock
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 5710
    In Stock
    13,50 € 11,25 €Ex.
    In Stock
  • Ref : 5712
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 5724
    In Stock
    33,90 € 28,25 €Ex.
    In Stock
  • Ref : 5725
    22,20 € 18,50 €Ex.
    In Stock
  • Ref : 5726
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 5704
    In Stock
    9,50 € 7,92 €Ex.
    In Stock
  • Ref : 5705
    In Stock
    10,50 € 8,75 €Ex.
    In Stock
  • Ref : 5707
    In Stock
    11,50 € 9,58 €Ex.
    In Stock
  • Ref : 5709
    In Stock
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 5711
    In Stock
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 5714
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 5715
    In Stock
    20,90 € 17,42 €Ex.
    In Stock
  • Ref : 5716
    In Stock
    22,90 € 19,08 €Ex.
    In Stock
  • Ref : 5727
    27,80 € 23,17 €Ex.
    In Stock
  • Ref : 5713
    In Stock
    17,50 € 14,58 €Ex.
    In Stock
  • Ref : 5718
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 5719
    18,90 € 15,75 €Ex.
    In Stock
  • Ref : 5717
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 5721
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 5722
    In Stock
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 5720
    In Stock
    28,90 € 24,08 €Ex.
    In Stock
  • Ref : 5723
    In Stock
    35,90 € 29,92 €Ex.
    In Stock
  • Ref : 4196
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion. For this reason, Mundorf produces coils with a large wire diameter for purists. It is therefore possible to achieve better inductances while maintaining low internal impedance and zero distortion.
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4197
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 4198
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4195
    In Stock
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 4199
    In Stock
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 4200
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 4201
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4202
    In Stock
    20,90 € 17,42 €Ex.
    In Stock
  • Ref : 4203
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4204
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4205
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 4206
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4208
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 4209
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 4210
    In Stock
    43,90 € 36,58 €Ex.
    In Stock
