Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Luboš W.
Rating
I use the power supply as a symmetrical power supply (2 pcs) to a low watt amplifier. It is almost noise free, no problems so far.
Johan v.
Good but small
Good switch but the button is small so not thumb size but more pinky sized
Johan v.
My favorite hook up wire
Easy to strip with a good stripper
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 4213
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. It is therefore possible to achieve better inductances while maintaining low internal impedance and zero...
    60,90 € 50,75 €Ex.
    In Stock
  • Ref : 4211
    In Stock
    47,90 € 39,92 €Ex.
    In Stock
  • Ref : 4215
    In Stock
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 4216
    In Stock
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 4214
    In Stock
    52,90 € 44,08 €Ex.
    In Stock
  • Ref : 4217
    In Stock
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 4218
    In Stock
    79,00 € 65,83 €Ex.
    In Stock
  • Ref : 4219
    In Stock
    75,00 € 62,50 €Ex.
    In Stock
  • Ref : 4220
    In Stock
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 4975
    In Stock
    Mundorf BS100 coils are high performance models for low frequency filtering. The core is made of Feron which is heat treated after production. This treatment gives it an optimal internal structure for good magnetic characteristics with very low losses and low distortion.
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 4987
    In Stock
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 4988
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 4978
    In Stock
    25,50 € 21,25 €Ex.
    In Stock
  • Ref : 4977
    In Stock
    25,00 € 20,83 €Ex.
    In Stock
  • Ref : 4981
    In Stock
    27,40 € 22,83 €Ex.
    In Stock
  • Ref : 2752
    In Stock
    Mundorf BS140 coils are high performance models for low frequency filtering. The core is made of Feron which is heat treated after production. This treatment gives it an optimal internal structure for good magnetic characteristics with very low losses and low distortion.
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 2753
    In Stock
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 6118
    In Stock
    62,90 € 52,42 €Ex.
    In Stock
  • Ref : 2765
    In Stock
    60,90 € 50,75 €Ex.
    In Stock
  • Ref : 6119
    In Stock
    85,00 € 70,83 €Ex.
    In Stock
  • Ref : 2757
    In Stock
    38,90 € 32,42 €Ex.
    In Stock
  • Ref : 6117
    In Stock
    42,90 € 35,75 €Ex.
    In Stock
  • 49,90 € 41,58 €Ex.
    In Stock
  • Ref : 2763
    In Stock
    58,90 € 49,08 €Ex.
    In Stock
  • Ref : 18331
    Metal foil coils are physically the best designed. The output quality is constant up to 100kHz and unwanted capacitive loads are very low. The stability of the coil is also remarkable: thanks to the large contact area between the winding and the polypropylene insulator, vibrations are eliminated.
    315,00 € 262,50 €Ex.
    In Stock
  • Ref : 12288
    399,00 € 332,50 €Ex.
    In Stock
  • Ref : 12287
    In Stock
    159,00 € 132,50 €Ex.
    In Stock
  • Ref : 2800
    In Stock
    25,90 € 21,58 €Ex.
    In Stock
  • Ref : 2801
    In Stock
    16,90 € 14,08 €Ex.
    In Stock
  • Ref : 2802
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 2799
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 2803
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 2804
    In Stock
    31,90 € 26,58 €Ex.
    In Stock
  • Ref : 2805
    In Stock
    22,90 € 19,08 €Ex.
    In Stock
  • Ref : 2806
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 2807
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 2808
    In Stock
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 2809
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 2810
    In Stock
    52,90 € 44,08 €Ex.
    In Stock
  • Ref : 2812
    In Stock
    64,90 € 54,08 €Ex.
    In Stock
