Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Tomasz C.
Powerful combination
The Wiim Ultra Streamer has all the bells and whistles in terms of connecting TV's, Record Player and all the streaming...
Jean Jacques R.
gaine large
j'ai du re-commander cette dimension pour mettre 2x cables de diam 7mm, je pensais que la gaine 7-14 pouvait faire 14mm de...
Jean-François G.
Nouvelle TV, nouvelle connectique: pas de sortie audio analogique ni de prise casque. L’utilisation de ce petit appareil a...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 16132
    In Stock
    The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all wirewound resistors, this film offers lower inductance. The copper is significantly softer than the metal oxide used in MOX resistors.
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16133
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 13615
    In Stock
    These coils are recommended for filtering bass speakers. Their low impedance improves impulse response for a loudspeaker with better handling.
    169,00 € 140,83 €Ex.
    In Stock
  • Ref : 1696
    The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum. In the ZOC, the center space is calibrated and adjusted by hand between the two laminar cores.
    154,90 € 129,08 €Ex.
    In Stock
  • Ref : 1695
    159,90 € 133,25 €Ex.
    In Stock
  • Ref : 1697
    In Stock
    he Zero Ohm Coil (ZOC) is a transformer format coil. It is made of FERON, a high quality material that limits distortion to a minimum.
    164,90 € 137,42 €Ex.
    In Stock
  • Ref : 1707
    In Stock
    339,90 € 283,25 €Ex.
    In Stock
  • Ref : 1708
    In Stock
    359,90 € 299,92 €Ex.
    In Stock
  • Ref : 1709
    In Stock
    379,90 € 316,58 €Ex.
    In Stock
  • Ref : 1710
    In Stock
    399,90 € 333,25 €Ex.
    In Stock
  • Ref : 1694
    149,90 € 124,92 €Ex.
    In Stock
  • Ref : 1698
    169,90 € 141,58 €Ex.
    In Stock
  • Ref : 1699
    189,90 € 158,25 €Ex.
    In Stock
  • Ref : 1701
    199,90 € 166,58 €Ex.
    In Stock
  • Ref : 1702
    In Stock
    209,90 € 174,92 €Ex.
    In Stock
  • Ref : 1700
    145,90 € 121,58 €Ex.
    In Stock
  • Ref : 1703
    219,90 € 183,25 €Ex.
    In Stock
  • Ref : 1704
    279,90 € 233,25 €Ex.
    In Stock
  • Ref : 1705
    299,90 € 249,92 €Ex.
    In Stock
  • Ref : 1706
    319,90 € 266,58 €Ex.
    In Stock
  • Ref : 6078
    Metal foil coils are physically the best designed. The output quality is consistent up to 100kHz and unwanted capacitive loads are very low. The stability of the coil is also remarkable: thanks to the large contact area between the winding and the polypropylene insulator, vibrations are eliminated.
    679,90 € 566,58 €Ex.
    In Stock
  • Ref : 6079
    759,90 € 633,25 €Ex.
    In Stock
  • Ref : 6080
    Metal foil coils are physically the best designed. Output quality is constant up to 100kHz, and unwanted capacitive loads are very low. Coil stability is also remarkable: thanks to the large contact area between the winding and the polypropylene insulator, vibrations are eliminated.
    849,90 € 708,25 €Ex.
    In Stock
  • Ref : 6077
    629,90 € 524,92 €Ex.
    In Stock
  • 949,90 € 791,58 €Ex.
    In Stock
  • Ref : 6082
    1 059,90 € 883,25 €Ex.
    In Stock
  • Ref : 6083
    1 199,90 € 999,92 €Ex.
    In Stock
  • Ref : 6084
    1 295,90 € 1 079,92 €Ex.
    In Stock
  • 1 441,90 € 1 201,58 €Ex.
    In Stock
  • Ref : 6087
    1 789,90 € 1 491,58 €Ex.
    In Stock
  • Ref : 6088
    1 989,90 € 1 658,25 €Ex.
    In Stock
  • Ref : 6089
    2 229,90 € 1 858,25 €Ex.
    In Stock
  • Ref : 4419
    The metallization of the MCap Supreme SilverGold capacitor foil is composed of pure Silver mixed with 1% very pure Gold. Gold modifies the crystal structure of silver and maximizes its excellent electrical conductivity.
    104,90 € 87,42 €Ex.
    In Stock
  • Ref : 2199
    175,90 € 146,58 €Ex.
    In Stock
  • Ref : 3654
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 20407
    The metallization of the Mundorf MCap Supreme SilverGold capacitor foil is composed of pure silver mixed with 1% very pure gold. Gold modifies the crystal structure of silver and maximizes its excellent electrical conductivity. The outstanding characteristics of the MCap Supreme - richness of detail and spatial quality of the music reproduced - are once...
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 3655
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 3656
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 3657
    In Stock
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 3658
    In Stock
    69,90 € 58,25 €Ex.
    In Stock
