Produit conforme, envoyé immédiatement, arrivée comme prévu : un sans faute !
Linear potentiometer 500k - Rotary Switch Bistable 250V / 4A
Replacement potentiometer / switch for amplifier or other devices that require repair or upgrade. Model approved 4A250V VDE / UL / CSA.
This potentiometer is designed to control a microcontroller, not to receive an audio signal directly. The three main soldering points on the side control the track. The two soldering points at the rear correspond to the switch.
Maximum power | 4A250V / 8A125V |
Resistance | 500k (linear) |
Certifications | VDE / UL / CSA |
Global dimensions | 47 x 30 x 24 mm |
Shaft diameter | 6mm |
Drilling diameter | 8 mm |
Shaft length | 18 mm |
Shaft | Notched |
Channel | N/A |
LED Color | N/A |
Resistance (Ohm) | 500000.0 |
Tolerance (%) | N/A |
Internal width | N/A |
Internal depth | N/A |
Internal height | N/A |
Number of positions | N/A |
Button type | N/A |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
