TINYSINE Potentiometer Kit V2 for DSP Amplifier Module
This kit includes 4 potentiometers and an adapter board. Each potentiometer module is equipped with a 10K potentiometer on the board.
Reference : 21388
9,17 €tax incl.
7,64 € tax excl.
Shipping date: 01-12-2026.
TinySine Kit Potentiometer Kit V2 for DSP Amplifier Module
Photo of the Potentiometer Kit V2 by Tinysine
This kit includes 4 potentiometers and an adapter board. Each potentiometer module is equipped with a 10K potentiometer on the board. It can work with the Tinysine DSP audio amplification board and control audio volume, bass, midrange, and treble by turning each potentiometer.
It is compatible with many TinySine modules:
  • TSA8804
  • TSA1701
  • TSA7551
  • TSA8800
  • TSA8802
  • TSA7802
When using this kit with the TSA1701 and TSA1702 models, you must first disconnect the solder pads located on the back of the board, otherwise the ADC port may be damaged.
Product typePotentiometer kit
Board dimensions20.5 x 12.5mm
Potentiometer shaft diameter6.75mm
Package1x DSP conversion board
4x TSA1301 potentiometer module
1x 6-pin JST XH cable
4x 3-pin JST XH cable
ShaftNotched
Channel2 (Stereo)
Resistance (Ohm)10000.0
Tolerance (%)N/A
