Ethernet to Optical Fiber Converter (Pair) Jack DC Power Supply
These devices are delivered in pairs and convert a 10/100/1000Base-T Ethernet signal to 1000Base-SX/LX optical fiber. This allows the signal to be isolated from the rest of the Ethernet network to limit noise, while enjoying the advantages of 1000Base-SX/LX optical fibre, i. e. the greatest possible transmission distance.
Reference : 13759
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 21-04-2026.
Ethernet Optical Converter
Ethernet Optical Fiber Converter (Pair)
Convertisseur Switch Ethernet 10/100/1000Base-TX vers fibre Optique 1000Base-SX/LX
These devices are delivered in pairs and convert a 10/100/1000Base-T Ethernet signal to 1000Base-SX/LX optical fiber. This allows the signal to be isolated from the rest of the Ethernet network to limit noise, while enjoying the advantages of 1000Base-SX/LX optical fibre, i. e. the greatest possible transmission distance. The fiber optic port supports multimode SX and single mode LX transmission standards for distances up to several kilometers.
The implementation is simple. Simply connect your network source (router, switch...) to the RJ45 connector of the first converter via a twisted pair Ethernet cable and then connect the two converters together with optical fiber. Finally, simply connect the second converter to your destination device (computer) in RJ45. LED indicators indicate the operating status of the device.
Power adapter 5VDC 2A via Jack DC 5.5/2.5mm sold separately.
Product typeEthernet to Optical fiber converter
ChipsetQCA8334-AL3C
Input1x Ethernet RJ45 10/100/1000Base-T
Output1x Optical SC 1000Base-SX/LX
Compatible Ethernet cable categoryCat5e / Cat6
Duplex modesFull Duplex or Half-Duplex
Supply voltage5VDC
Dimensions94 x 71 x 27mm
Case materialMetal
ColorGray
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorOptical
ConnectorRJ45
Conductors material (Cable)Optical Fiber
2 reviews
un petit plus
Le prix tout petit s envole quand on a rajouté 2 alimentations 5 volts correctes,un cable rj 45 plaqué argent et un câble optique .
Mais le clignotement des petites les vertes fait tout oublier.
This review has been posted for Ethernet to Optical Fiber Converter (Pair) Jack DC Power Supply
Work perfect
It comes with Asian power suply no need to buy another just adapter
Ir works perfect
These devices are delivered in pairs and convert a 10/100/1000Base-T Ethernet signal to 1000Base-SX/LX optical fiber. This allows the signal to be...
