SC / SC 10m
This fiber optic cable allows network data to be transmitted using light signals. This makes it possible to achieve much higher transmission rates than with a conventional RJ45 Ethernet cable with copper conductors. This cable can therefore be used to connect an Internet box with a FTTH fibre source or a switch with an optical fibre connector.
| Specifications | |
| Product type | Optical fiber cable |
| Length | 10m |
| Connectors type | SC |
| Propagation mode | Mono Mode |
| Conductor section | 9/125µm |
| Cable diameter | 2.8mm |
| Sheath | PVC (LSOH standard) |
| Attenuation | 0.38/0.24 dB/km |
| Général | |
| Color | Sheath : Yellow Connectors : Blue |
| Length (m) | 10.0 |
| Shielding | No |
| Section (mm²) | N/A |
| Connector | Optical |
| Conductors material (Cable) | Optical Fiber |
| Conductors Plating (Cable) | None |
