PANGEA PREMIER SE Ethernet Cable RJ45 Cat7 3m
If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its First Ethernet SE, Pangea offers cables using top-of-the-range materials and a careful design to ensure excellent performance.
Reference : 21187
89,90 €tax incl.
74,92 € tax excl.
Pangea Premier SE Ethernet Cable RJ45 Cat7 Silver Plated Cardas Copper Triple Shielding 3m
Photo of the Pangea Premier SE Ethernet cable
If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its Premier SE Ethernet, Pangea offers RJ45 cables using top-of-the-range materials and a careful design to ensure excellent performance.
Pangea Premier SE: Cardas copper & silver plating
The Pangea Premier SE Ethernet integrates 26AWG (0.129mm²) copper cardas conductors with silver plating to ensure maximum conductivity. Cardas Copper, developed by George Cardas, has an exceptional quality. The latter is mined in Arizona and then sent to a New England factory where it is very slowly transformed into conductors via a long process to maximize its purity. The conductors are then delivered to a second factory in order to apply the Silver plating.
Pangea Premier SE: PE insulation & triple shielding
Always with performance in mind, the cable is covered with a PE sheath. In addition, each conductor is individually shielded, a requirement for Cat7 Ethernet standard and triple shielding is then added to minimize the negative impact of EMI / RFI interference.
Product typeRJ45 Ethernet Cable
Connectors2x RJ45
Length3m
Ethernet categoryCat7
Conductors materialCardas Copper
Conductors platingSilver
Conductors section0.129mm² (26AWG)
InsulationPE
ShieldingIndividual shielding of each conductor + triple shielding
Connectors platingGold
Cable colorBlack and Gray
Package1x Pangea Premier SE RJ45 Ethernet Cable
Length (m)3.0
ShieldingYes
Section (mm²)0.129
ConnectorRJ45
PANGEA PREMIER SE Ethernet Cable RJ45 Cat7 Silver Plated Cardas Copper Triple Shielding 3m
If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver...
