FURUTECH FT-7254 (R) Jack 2.5mm Rhodium plated Ø5mm (Unit)
10%
Reduced price!
Reference : 11379
Limited time offer:
38,90 €tax incl.
-10%
35,01 €tax incl.
29,17 € tax excl.
Last items in stock !
Shipping date: 08-07-2025.
The Furutech jack 2.5mm TTRS FT-7254 (R) connector is the result of meticulous Japanese engineering after careful consideration of various suitable materials.
The FT-7254 (R) is constructed with hybrid alpha copper-plated rhodium and special resin insulation for minimum impedance in a non-magnetic stainless steel housing for superior damping.
This Furutech connector is one of the few solutions for high quality 2.5mm 4-pole jack cable design.
Features:
  • Main driver : Hybrid pin constructed with rhodium alpha copper plating
  • Ground conductor: non-magnetic α (Alpha) rhodium copper hybrid.
  • Insulation with Furutech special audio quality resin.
  • Housing: Non-magnetic stainless steel
  • Cable clamp: Copper alloy
  • Specified for basic insulation diameters up to 5.0mm
  • Connections: Solder
Dimensions :
  • Inner body :10.3mm approximately
  • Screw-in cylinder body: 25mm
  • Total length: approx. 39.6 mm
  • Sold individually
Max cable diameter (mm)5.0
Mounting typeTo weld
ConnecticMale
Contacts number4
