Gold Plated IEC C7 Connector Alpha Treatment Ø10.5mm
Benefiting from a high quality design, the IEC C7 Furutech FI-8.1 connector incorporates high-performance components to ensure excellent conductivity. Thus, the connector contacts are made of a Copper Alloy with gold plating and α (Alpha) treatment. This treatment consists of a first cryogenization step and a second demagnetization step, which increases the conductivity of the contacts.
The connector body is made of Nylon. In addition, this FI-8.1(G) incorporates a brand new cable holding and resonance control system, all in a more compact format ideal for use in confined spaces.
| Specifications | ||
| Product type | IEC C7 Connector | |
| Contacts material | Copper alloy | |
| Contacts plating | Gold | |
| Contacts treatment | α (Alpha) | |
| Shelle material | Nylon | |
| Min / Max cable diameter | 5mm / 10.5mm | |
| Max cable section | 2mm² / 14AWG | |
| Connection type | To solder | |
| Dimensiosn | 14.5 x 21.5 x 51.2mm | |
| Weight | 17g | |
| Max cable diameter (mm) | 10.5 |
| Mounting type | To weld |
| Connectic | Female |
| Connector | IEC C7 |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
| Rated current (A) | N/A |
