OYAIDE C-004 Connector IEC Beryllium + Platinum / Palladium Ø17mm
4.8 / 5
Reference : 5475
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 16-05-2025.
These 100% Japanese manufacturing connectors have been designed to provide a high quality and reliable standard for your audio connections.
Oyaide selects each material to achieve a homogeneous connector, reducing vibration and improving sound quality.
This series is one of the rare to use beryllium copper contacts, this material having the resistance of brass, with the conductivity of pure copper.
Ensuia rare metal base plating was selected, a first layer of 0.5μ Platinum and then 0.3μ Palladium
Features:/ Strong>
  • Contactscopper Beryllium
  • Platinum Platinum 0.5μ + Palladium 0.3μ (Nickel free)
  • Conductors up to 5.5mm²
  • 30% fiberglass filled body for increased rigidity
  • Stainless steel screws
  • Cable diameter: 6 to 17mm
  • Tension / Courant : 250V 10A CE
Technical Specifications:
  • Total diameter: 38mm
  • Overall Length: 70.75mm
Max cable diameter (mm)17.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Contacts Material (Connector)Beryllium Copper
Contacts Plating (Connector)Platinum
Contacts Plating (Connector)Palladium
Rated current (A)10.0
12 reviews
OMG
I got: seat at the mixing desk
I paid: the bass
And I love this
This review has been posted for OYAIDE C-004 Connector IEC Beryllium + Platinum / Palladium Ø17mm
finesse et resolution
Bonsoir , 3 eme iec 004 sur mon systeme ,la voila sur l alimentation de mon phono ( allo shanti) celle ci remplace une iec iego or , la 004 a une grosse resolution dans le bas medium ,medium ,haut medium, aigu fin qui file, des basses rapide,precises, un poil legere peut etre , pour moi la meilleure iec que j ai testé ! la sonorité de la 004 est basé surtout dans la finesse ,transparence ,rapidité. Franck
Impressionnant mais...
Qualité de fabrication irréprochable.
La tension des lames optimise le contact, il est assez difficile à brancher la première fois.
La quantité d'information que ce connecteur permet de révéler est bluffante, surtout avec un composant numérique.
Le contrôle du Grave est fabuleux et même si il apparait moins présent sa présentation reste dynamique, rapide et très tendue : vivante !
Le medium est beaucoup moins fluide qu'avec des connecteurs plaqués or ou rhodium.
L'aigu offre une quantité de détail bluffante à la première écoute, avec beaucoup d'extension mais à la longue cela ne sera pas toujours confortable.
Une prise qui amène beaucoup de transparence et de réalisme mais qui selon le câble utilisé et le composant associé pourra s'avérer être difficile à intégrer.
Jorma Design équipe certains de leurs cables secteur avec ce modèle.
Selon le type de musique et les goûts de chacun il pourra faire des merveilles ou introduire un déséquilibre évident dans le registre.
Un chose est certaine le C-004 ne pourra s'inviter que dans des systèmes très haut de gamme : cette prise ne pardonne rien.
Super prises IEC
J'ai acheté 4 de ces IEC Oyaide pour équipement de différents appareils. Je confirme les qualités décrites dans les différents commentaires à savoir neutre, rapide, meilleur perception des voix et très belle scène sonore (bien ouverte avec une meilleure séparation des voix). Sur mon système elle ont eu l'effet décrit ci-dessus sur la source, le préampli et la barette multiprise, avec probablement des effets cumulés. Par contre elles n'ont pas du tout matchés avec mes blocs mono Aesthetix (message sonore trop desséché, l'écoute devient raide). J'ai donc réinstallé les prises IEC Iego 8085 pour leur côté chaleureux et mélodieux. Toutes ces oyaide 004 sont associées en shucko avec d'autres marques pour mixer les sonorités.
Excellent
Testé par hasard suite à la lecture d'un test sur un forum, je confirme les avis précédent : le son est plein et bien équilibré.
