RAMM AUDIO IEC-01C Power Connector IEC C15
New
The IEC-01C from Ramm Audio is an IEC C15 connector with a high-quality black nylon body. Stylish and sturdy, this chassis is ideal for integrating sophisticated, high-end cables. Its proportions make it the perfect choice for cables and conductors with a large diameter.
Reference : 20852
69,00 €tax incl.
57,50 € tax excl.
Shipping date: 20-06-2025.
RAMM AUDIO IEC-01C Power Connector IEC C15 Gold-Plated Copper 24K Ø17mm
RAMM AUDIO IEC-01C : Front view
This connector accepts cables with a diameter of up to Ø17mm. Thanks to a rubber cable clamp, your thick cables will be held securely in place. The pure copper contacts are cryogenically treated and plated with 3µ thick 24k gold for maximum conductivity and increased resistance to oxidation and corrosion.
Finally, it should also be noted that the internal connection terminals are equipped with large fixing screws and a particularly large contact surface. This means that no soldering is required to integrate your cable, and large-diameter conductors are held firmly in place.
Product typeIEC C15 power connector
Mounting typeTo screw
Max cable diameterØ17mm
Max conductors section5.26mm² (10 AWG)
Contacts treatmentCryogenic
Contacts platingGold 24k 3µ
Conductive materialPure cooper
Dimensions39.5 x 82.5mm
Weight62g
PackageSold by unit
Max cable diameter (mm)17.0
ConnecticFemale
ConnectorIEC C15
Rated current (A)N/A
The IEC-01C from Ramm Audio is an IEC C15 connector with a high-quality black nylon body. Stylish and sturdy, this chassis is ideal for integrating...
