Connector
Max cable diameter (mm)
Rated current (A)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Nicolas B.
Steve D.
Dayton spa300-D
Genalex
Schuko Connectors
Discover our range of Schuko power connectors, for the design of your HiFi power cables.
