OYAIDE P-079E Schuko Type E/F Power Connector 24K Gold Plated Phosphore Bronze Ø17mm
Reference : 8289
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 22-09-2026.
schuko high fidelity stable signal power connector
Oyaide P-079th theaded power connector
These 100% Japanese-made connectors have been designed to provide a quality in order to galvanize your audio connections. Oyaide has selected each material to obtain a top-reliable connector, reducing vibrations to the benefit of longevity and signal stability.
The contacts are made of bronze phosphor with double polishing and 24K gold plating to ensure best conductivity. In addition, the tightening system (screw) accepts large conductors types (up to 6mm in diameter).
The whole system is protected by a robust capsule made of 30% glass fiber. A wide clamp is used to secure the cable and prevent movement while allowing large cable diameters (up to 17mm).
TypePower connector
FormatCEE 7/7
MaterialsBody: Fiberglass
Screws: Stainless Steel
Contacts: bronze phosphore (double polishing)
Plating: Gold 24k
Nominal voltage250V 16A
Suported Cable diameter6.5 to 17 mm⌀
Maximum driver diameter6 mm⌀
Max cable diameter (mm)17.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
Douceur et tenue
Schuko oyaide 79 en bronze et plaqué or possede un son riche ,tres doux, ( indulgente) ronde et puissante,avec un medium tres plein tenue excellente,,ideale pour systeme un peu montant ,trop clair. Pour moi une des meilleures schukos .Franck
 (3)
This review has been posted for OYAIDE P-079E Schuko Type E/F Power Connector 24K Gold Plated Phosphore Bronze Ø17mm
