VIBORG LE505G Angled Schuko Connector Type E/F
This Viborg LE505G angled Schuko connector is ideal for designing and upgrading high-performance, high-quality power cables. Its pure copper contacts with OFC copper / silver / 24k gold plating ensure very high conductivity and excellent resistance to oxidation. The insulation is made of nylon and fiberglass, robust and lightweight materials that are also electromagnetically neutral. Assembly is very simple thanks to a screw-lock system.
Reference : 22007
65,90 €tax incl.
54,92 € tax excl.
Shipping date: 01-12-2026.
Viborg LE505G Angled Schuko Type E/F Connector Pure Copper OFC Copper / Silver / 24k Gold Plated Ø19mm
VIBORG LE505G
Dimensions VIBORG LE505G
Technical Specifications
Product typeAngled Schuko connector
Contact materialPure copper
Contact platingOFC copper / silver / 24k gold
InsulationNylon and fiberglass
AssemblyScrew-lock
Compatible cable diameterØ6-19mm
Maximum conductor diameter / cross-sectionØ4.5mm / 19mm²
Voltage / Current250VAC 16A
Maximum cable diameterØ7mm-Ø19mm
Dimensions46.97 x 57.7 x 42.4 mm
Package1x Viborg LE505G
Max cable diameter (mm)19.0
Mounting typeTo screw
ConnecticMale
ConnectorSchuko
Contacts Plating (Connector)Copper
Rated current (A)16.0
VIBORG LE505G Angled Schuko Connector Type E/F Pure Copper OFC Copper / Silver / 24k Gold Plated Ø19mm
This Viborg LE505G angled Schuko connector is ideal for designing and upgrading high-performance, high-quality power cables. Its pure copper...
