Best souding plug for the money, and more
In terms of sound quality, the plug easily betters ANY in its price range and also many much more expensive ones. But it has idiosyncrasies in its structure that make it less easy to use by non experienced users. The slot head screws that are used to hold the wires in place are certainly more difficult to use than the more common Allen screws used buy other manufacturers but the job can be done perfectly if you know or understand how to screw them without damaging the head. Don’t use ANY screwdriver but one that is no wider than the screw itself so that it can follow the screw into the hole, if needed. While screwing, try to keep the screwdriver strictly in line with the axle of the screw and centered into the slot and apply as much force as you can, pushing the scew to the direction of the screwing but without disturbing the balance. Do not overtighten any screw on the plug! Also mind you that the cable clamping system can only fix cables with diameter larger than 12mm and up to 18mm
This review has been posted for YARBO GY-901 Schuko Type E/F Power Connector Red Copper Ø18mm In terms of sound quality, the plug easily betters ANY in its price range and also many much more expensive ones. But it has idiosyncrasies in its structure that make it less easy to use by non experienced users. The slot head screws that are used to hold the wires in place are certainly more difficult to use than the more common Allen screws used buy other manufacturers but the job can be done perfectly if you know or understand how to screw them without damaging the head. Don’t use ANY screwdriver but one that is no wider than the screw itself so that it can follow the screw into the hole, if needed. While screwing, try to keep the screwdriver strictly in line with the axle of the screw and centered into the slot and apply as much force as you can, pushing the scew to the direction of the screwing but without disturbing the balance. Do not overtighten any screw on the plug! Also mind you that the cable clamping system can only fix cables with diameter larger than 12mm and up to 18mm
