DAYTON AUDIO DCS385-4 Speaker Driver Subwoofer 300W 4 Ohm 92dB 19Hz - 200Hz Ø38.1cm
The DCS385-4 is a standard subwoofer that will fit most systems, whether replacing a HS subwoofer of the same size or simply creating a new subwoofer. For maximum versatility, this speaker has been designed to be suitable for both bass reflex and closed cabinet applications.
By buying this product you get 20 loyalty points
Reference : 15229
209,95 €tax incl.
174,96 € tax excl.
Shipping date: 17-09-2026.
Grantie 5 ans
dayton audio dsc385-4 subwoofer
The DCS385-4 is a standard subwoofer that will fit most systems, whether replacing a HS subwoofer of the same size or simply creating a new subwoofer. For maximum versatility, this speaker has been designed to be suitable for both bass reflex and closed cabinet applications. The very robust diaphragm and the wide suspension ensure a high linear excursion for excellent low frequency performance.
Speaker typeSubwoofer
Nominal diameter38.1cm (15")
Diaphragm materialPaper / Kevlar
Magnet materialFerrite
Voice coil wire materialCopper
Overall outside diameter387mm
Depth185.4mm
Power handlingRMS : 300W
MAX : 600W
Impedance
Sensitivity91.7dB @ 2.83V/1m
Frequency response19Hz - 200Hz
DC Resistance (Re)3.3Ω
Voice coil inductance (Le)2.2mH
Mechanical Q (Qms)5.27
Electromagnetic Q (Qes)0.42
Total Q (Qts)0.39
Moving mass of diaphragm (Mmd)273g
Mechanical compliance of suspension (Cms)0.3mm/N
Surface area of cone (Sd)850.1cm²
Maximum linear excursion (Xmax)9.3mm
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume108.45L
Sealed F339Hz
Vented Volume347.16L
Vented F322Hz
Speaker Power (W RMS)250.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)381.0
Diaphragm typePaper
Diaphragm typeKevlar
Efficiency / Sensitivity (dB)92.0
Max Linear Excursion (Xmax) (mm)9.3
Lowest frequency (Hz)19
Highest frequency (Hz)200
Highest frequency (Hz)500
The DCS385-4 is a standard subwoofer that will fit most systems, whether replacing a HS subwoofer of the same size or simply creating a new...
