DAYTON AUDIO LS10-44 10" Haut-Parleur Subwoofer Aluminium 250W 4+4 Ohm 86.5 30Hz - 300Hz Ø25cm
Reference : 13320
177,00 €tax incl.
147,50 € tax excl.
Shipping date: 29-09-2026.
Grantie 5 ans
Dayton Audio LS10-44 10 "
Subwoofer 2x 4Ω
This serious type subwoofer speaker is ideal to give body to the lower frequencies of your music while consuming very little space.
Despite its remarkably compact dimensions, the LS10-44 offers considerable power in the bass, especially with a carefully controlled tour of more than 10mm.
The integration will be particularly facilitated by the very thin speaker (only 8.6cm). It can then be installed in housings of small sizes which are usually unsuitable for serious loudspeakers while maintaining full power.
This will position them on a wall, on the floor or the ceiling without difficulty or particular constraint. The most daring will also enjoy an ideal form for folk intrégrations, as in a seat back or in a vehicle sound environment.
An aluminum piston with hexagonal pattern replaces the traditional cone subwoofer.
A double-balanced coil configuration offers exemplary stability of motion while minimizing the overall distortion. The humbucking provides tremendous efficiency of the engine and operates an cermique heart maagnétique ferrite authorizing a connection 2 or 8 ohms
Aluminum rings allow to lower the inductance while promoting rapid and sharp response at low frequencies of the spectrum.
TypeTop Woofer (subwoofer)
Nominal diameter25.4cm
PowerRMS: 250W
Max: 500W
Impedance4 + 4 ohms
Frequency response30 - 300Hz
Sensitivity86.5 dB @ 2.83V / 1m
reel diameter5.08cm
Resonance Frequency34.3 Hzfs
DC resistance7.4 ohmsRe
Indutance Coil5.25 mHThe
Mechanical Quality Factor5.15qms
Electrical Quality Factor0.47Qes
Total Quality Factor0.43qt
Volume equivalent Compliance1.08 ft.³Vas
Compliance suspension0.16 mm / Ncms
Mobile mass132gmms
maximum linear excursion10mmXmax
membrane emissive surface366.4 cm²sd
MembraneFiberglass
contoursRubber
wiringCCA
FormAluminum
StructureSteel
MagnetFerrite
overall external diameter272.2 mm
Drilling diameter238.5 mm
Depth84.5 mm
Number of mounting holes8
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume12.74 Litres
Sealed F363 Hz
Vented Volume31.15 Litres
Vented F332 Hz
Speaker Power (W RMS)250.0
Speaker TypeSubwoofer
Impedance (Ω)4+4
Loudspeaker diameter (mm)250.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)10.0
Lowest frequency (Hz)30
Highest frequency (Hz)300
Download
2 reviews
DAYTON AUDIO LS10-44 10 "
DAYTON AUDIO LS10-44 10 "a subwoofer with an unbeatable price quality, quality materials used, professional features with a very good sound quality highlighting the low frequencies that make it an excellent subwoofer at a relatively low price for performance, we must highlight its low design with excellent aesthetics giving a professional sound.
This review has been posted for DAYTON AUDIO LS10-44 10" Haut-Parleur Subwoofer Aluminium 250W 4+4 Ohm 86.5 30Hz - 300Hz Ø25cm
Subwoofer Dayton Audio LS10-44 10"
