MONACOR SPH-200CTC Speaker Driver Woofer
This Monacor SPH-200CTC dual-coil woofer is particularly well-suited to the natural reproduction of vocals, delivering incredible bass depth. It also delivers astonishingly accurate sound.
Reference : 1932
115,00 €tax incl.
95,83 € tax excl.
Monacor SPH-200CTC Speaker Driver Woofer Dual Coil 2x60W 2x8Ω 88dB 22Hz-4000Hz Ø20.3cm
Monacor SPH-200CTC image
Dimensions and performance of the Monacor SPH-200CTC
Speaker driver typeWoofer
Nominal diameterØ20.3cm
Power handlingRMS : 2x60W
Max : 2x100W
Impedance2x 8Ω
Frequency response22Hz - 4000Hz
Sensitvity88dB/W/m
Voice coil diameterØ50mm
Magnet weight840g
Magnet diameterØ120mm
Weight2.76kg
Thiele-Small parameters
Resonant frequency (Fs)22Hz
DC resistance (Re)2x 6.8Ω / 3.4Ω
Voice coil inductance (Le)2x 1.0mH / 1.0mH
Mechanical quality coefficient (Qms)4.91
Electromagnetic quality coefficient (Qes)0.23
Total quality factor (Qts)0.22
Equivalent volume (Vas)75L
Mechanical suspension compliance (Cms)1.16mm/N
Moving mass (Mms)45g
Force factor (BL)9Tm
Max linear excursion (Xmax)±3.75mm
Effective cone area (Sd)214cm²
Materials
ConeCarbon fiber
BasketDiecast
Voice coil formerKapton
Mounting informations
Total external diameterØ211mm
Cutout diameterØ181mm
Depth115mm
Bolt circle diameterØ181mm
Number of mounting holes4
Speaker Power (W RMS)60.0
Speaker TypeSubwoofer
Impedance (Ω)8
Loudspeaker diameter (mm)250.0
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)3.7
Lowest frequency (Hz)N/A
Highest frequency (Hz)4000
MONACOR SPH-200CTC Speaker Driver Woofer Dual Coil 2x60W 2x8 Ohm 88dB 22Hz-4000Hz Ø20.3cm
This Monacor SPH-200CTC dual-coil woofer is particularly well-suited to the natural reproduction of vocals, delivering incredible bass depth. It...
