In-Ears Tips Memory Foam S / M / L 4.5mm Grey (3 pair)
These in-ear tips for earphones are made of memory foam as well as a sound guide tube allowing a reduction of noise on low frequencies. The memory foam also blocks out surrounding sounds by inserting deep into the ear canal. Foam tips are twice as effective in terms of sound insulation as silicone tips.
Reference : 17433
6,90 €tax incl.
5,75 € tax excl.
Shipping date: 21-04-2026.
In ear tips for earphones
Memory Foam S / M / L 4.5mm Grey (3 pairs)
Memory foam for confort
The memory foam is made of high quality polyurethane and does not contain latex. It is this specificity that will bring you great comfort over long periods of use. In addition, the foam allows total isolation of your ear canal to reduce ambient noise. These in-ear tips will allow you to comfortably listen to your favorite music all day long.
Compatible with 4.5-5mm in-ear earphones
These headphone foams will be compatible with a large number of in-ear models since they are designed for 4.5-5mm audio ports. In addition, you will find different sizes (S, M, L) in order to be able to select the best tips for your ears.
Technical caracteristics
Product typeMemory foam in-ear tips for earphones
Internal diameter4.5mm (elasticity 5mm)
MaterialsMemory foam (polyurethane)
ColorGrey
Quantity1x in-ear tips Grey S
1x in-ear tips Grey M
1x in-ear tips Grey L
These in-ear tips for earphones are  made of memory foam  as well as a sound guide tube allowing a  reduction of...
