Heatshrink Tubing 2:1 Ø1.5-13mm White 10cm (Set x100)
4.0 / 5
Reference : 8794
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 19-08-2025.
Pack of 100 white heat shrink tubes of 6 different diameters.
A ratio of 2: 1 means that the diameter of the sheath once heated will be divided by 2: for example for a 12mm sheath, after being heated its diameter will be 6mm.
Specifications:
  • Retractable Ratio: 2: 1
  • Diameters:
    • 1.5 mm (30 pcs.)
    • 2.5 mm (30 pcs)
    • 4.0 mm (20 pcs)
    • 6.0 mm (10pcs)
    • 10 mm (6 pcs)
    • 13 mm (4 pcs.)
  • Length: 10cm
  • Color White
  • Shrink temperature approx. 120 ° C
https://www.audiophonics.fr/images2/8794/8794_gaines_thermo_kit_blc_1.jpg
ColorWhite
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)10.0
Max cable diameter (mm)4.0
Max cable diameter (mm)1.5
Max cable diameter (mm)6.0
Max cable diameter (mm)13.0
Max cable diameter (mm)2.5
2 reviews
Pratique
Un très large choix de diamètre avec des longueurs suffisantes pour bien finir ses montages.
Cette gaine reste blanche et bien blanche je déconseille l'utilisation du briquet pour un fini impeccable... respecter votre travail !
This review has been posted for Heatshrink Tubing 2:1 Ø1.5-13mm White 10cm (Set x100)
guaine discrete
guaine discrete
