AUDIOPHONICS Heat Shrink Tubing 3:1 Ø18mm Black (x2)
This set of 2 black heat-shrinkable sleeves allows you to offer your cables an excellent finish with a clean result. The Audiophonics logo is affixed to the sheath.
Reference : 20862
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 18-11-2026.
Audiophonics Heat Shrink Tubing for Cables 3:1 Ø 18mm Black (x2)
Audiophonics Heat Shrinkable Sleev
This set of two black heat-shrinkable sleeves allows you to offer your cables an excellent finish with a clean result. The Audiophonics logo is affixed to the sheath.
The 3:1 retractation ratio of this sleeve means that once heated, the diameter of the sleeve will be divided by 3.
Product typeHeat shrinkable sleeve
Max cable diameter18mm
Retractation ratio3:1
Dimensions50 x 30mm
Quantityx2 (2 units)
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)18.0
Excellent rapport qualite/prix
Utilises avec cable HP Canare 2F11S. Mise en oeuvre facile, la gaine se retracte rapidement et reste stable dans le temps. Permert d'obtenir une finition de cable tres propre.
This review has been posted for AUDIOPHONICS Heat Shrink Tubing 3:1 Ø18mm Black (x2)
This set of 2 black heat-shrinkable sleeves allows you to offer your cables an excellent finish with a clean result. The Audiophonics logo is...
