AUDIOPHONICS Heat Shrink Tubing Ø18mm Red (x2)
This set of 2 red heat-shrinkable sleeves allows you to offer your cables an excellent finish with a clean result. The Audiophonics logo is affixed to the sheath.
Reference : 20866
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 18-11-2026.
Audiophonics Heat Shrink Tubing for Cables 3:1 Ø18mm red (x2)
Audiophonics Heat Shrinkable Sleeve
This set of two red heat-shrinkable sleeves allows you to offer your cables an excellent finish with a clean result. The Audiophonics logo is affixed to the sheath.
The 3:1 retractation ratio of this sleeve means that once heated, the diameter of the sleeve will be divided by 3.
Product typeHeat shrink tubing
Max cable diameter18mm
Retractation ratio3:1
Dimensions50*30mm
ColorRed
Quantityx2 (2 units)
ColorRed
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)18.0
AUDIOPHONICS Heat Shrink Tubing 3:1 Ø18mm Red (x2)
This set of 2 red heat-shrinkable sleeves allows you to offer your cables an excellent finish with a clean result. The Audiophonics logo is affixed...
