AUDIOPHONICS Heat Shrink Tubing Ø25mm Red (x2)
This set of 2 red heat-shrinkable sleeves provides an excellent finish for your Audiophonics loudspeaker and mains cables, for a neat, clean result when identifying plus and minus or right and left polarities.
Reference : 20870
4,00 €tax incl.
3,33 € tax excl.
Shipping date: 18-11-2026.
Audiophonics Heat Shrink Tubing 3:1 Ø25mm Red (x2)
AUDIOPHONICS Heat-shrink sleeve
This set of two red heat-shrinkable sleeves provides an excellent finish for your Audiophonics loudspeaker and mains cables, for a neat, clean result when identifying plus and minus or right and left polarities.
A ratio of 3:1 means that the diameter of the sheath once heated will be divided by 3: for example, for a 12mm sheath, after being heated its diameter will be 4mm.
Features :
  • Shrink ratio: 3:1.
  • Dimensions : 4.2.cm x 5cm.
  • Packaging : 1 pair. (2 black).
ColorRed
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)25.0
AUDIOPHONICS Heat Shrink Tubing 3:1 Ø25mm Red (x2)
This set of 2 red heat-shrinkable sleeves provides an excellent finish for your Audiophonics loudspeaker and mains cables, for a neat,...
