Clean, very deep, very very powerful and stable even for the highest levels: this is how it is to react a serious Hi-Fi embedded top level in smaller enclosures. The new SONIC bass meets these requirements perfectly, and at a price that can only be realized by CARPOWER for these High Tech woofers.
Top Class Hi-Fi Subwoofer, 2x500 W MAX, 2x300WRMS, 2x2 Ω
10 "high-powered double-coil bass speaker, solid steel molded bowl, the carbon fiber membrane is surrounded by an exclusive long-travel rubber suspension and even the 25 cm SONIC is controlled by the same system The linear excursion is +/- 25 mm at full efficiency and allows an absolutely breathtaking bass reproduction.The output is certainly not extraordinarily high but you can reach levels deafening, combined with a very high power rating. The necessary speakers with only 15 liters in a cabinet cabinet or 25-35 liters in bass reflex are so small that the SONIC-10 can sometimes only be gigantic dimensions on the outside.
| Specifications Speakers | |
| Impedance (Z) | 2x2 Ω |
| Resonance frequency (fs) | 31 Hz |
| Maximum bandwidth | f3-300 Hz |
| Maximum power | 2x500WMAX |
| Rated power (P) | 2x300WRMS |
| Average sound pressure (1 W / 1 m) | 84 dB |
| Compliance susp. (Cms) | 0.14 mm / N |
| Moving mass (Mms) | 188 g |
| Mechanical overvoltage. (Qms) | 8.25 |
| Electrical overvoltage (Qes) | 0.53 |
| Fact. total surge (Qts) | 0.49 |
| Volume equ. (VAS) | 24 l |
| DC resistance. (Re) | 2x1.9 Ω / 1x3.8 Ω |
| Force factor (BxL) | 17Tm |
| Inductance coil (The) | 2x0.7 mH / 1x2.8 mH |
| Coil diameter | 75 mm |
| Coil holder | KAPTON |
| Linear excursion (X MAX) | ± 25 mm |
| Transmitting surface (Sd) | 346cm2 |
| Magnet Weight | 180 oz |
| Weight | 14.5 kg |
