DOUK AUDIO VU3PRO Audio Selector Switch VU Meter Yellow
The Douk Audio VU3PRO is an innovative and comprehensive audio solution combining amplifier switching, speaker selection, and dynamic visual display thanks to its two large retro analog VU meters. Designed for demanding audiophiles, this rugged enclosure features a 2-input/2-output selector that allows you to easily switch between two amplifiers or two pairs of speakers without having to disconnect cables, while supporting up to 350W of power per channel.
Reference : 21466
169,00 €tax incl.
140,83 € tax excl.
Shipping date: 20-11-2026.
Douk Audio VU3PRO Audio Selector Switch VU Meter Yellow
Photo of the DOUK AUDIO VU3PRO
With a transmission power of up to 350W, the VU3PRO is perfectly suited for modern high-power amplifiers. It offers broad compatibility with digital and tube amplifiers, including BTL, Class A, B, AB, and D architectures, and easily handles TPA3255 amplifiers up to 300W as well as demanding floorstanding speakers, while preserving audio signal integrity.
In terms of components and build quality, the VU3PRO uses high-capacity 250V 5A AC relays, high-precision current sensors, and large copper-plated speaker terminals, ensuring reliable signal transmission with no noticeable loss of sound quality.
Aesthetically, its elegant metal chassis and enlarged retro VU meters (85 × 45 mm) create a visual effect that is both vintage and modern, enhanced by 35 lighting color options and 5 brightness levels for a customizable look that matches your setup.
In terms of connectivity, the VU3PRO is equipped with female banana plugs for audio inputs and outputs, a USB Type-C power supply (DC 5 V ≥ 2 A), and a built-in microphone for audio detection. It also comes with a handy remote control, making it easy to adjust settings even from a distance.
DOUK AUDIO VU3PRO in action
Douk Audio VU3PRO: Splitter function, transform a 2.0 amplifier into a 4.0 system
The Douk Audio VU3PRO is not just a simple switch: it can also function as a distribution box, allowing you to connect two pairs of speakers simultaneously. This feature effectively transforms a 2.0 amplifier into a 4.0 configuration, offering wider and more immersive sound distribution. Ideal for providing sound to multiple areas or enjoying two sets of speakers in parallel, the VU3PRO offers great flexibility of use without the need for additional equipment.
Transform your 2.0 system into a 4.0 system
Douk Audio VU3PRO: Large-format, highly customizable analog VU meters
The Douk Audio VU3PRO is equipped with two large custom analog VU meters, integrated into a generously sized chassis ensuring perfect readability and optimal visual compatibility with hi-fi audio equipment. Designed to offer both a functional and aesthetic experience, these VU meters transform every listening session into a true audio-visual spectacle, fully customizable thanks to numerous advanced settings.
20-level gain adjustment
Precise gain adjustment allows the display amplitude to be adapted to both weak and strong signals. This prevents the needle from remaining stationary at low levels or becoming visually saturated at high volumes, ensuring a consistently balanced and readable display.
30-level sensitivity adjustment
The 30-level adjustable sensitivity allows you to fine-tune the responsiveness of the needles so that they accurately follow every variation in the audio signal. This adjustment ensures perfect synchronization with the rhythm and dynamics of the music, regardless of the source used.
Customizable lighting: 35 colors and 5 brightness levels
The VU meters feature 35 selectable backlight colors and 5 brightness levels, allowing for optimal adaptation to ambient lighting. This allows you to harmonize the appearance of the VU3PRO with your audio system or create a unique visual atmosphere, whether in a dark or bright environment.
VUmeters from DOUK AUDIO VU3PRO
Overview of the Douk Audio VU3PRO
Overview of the DOUK AUDIO VU3PRO
1Gain adjustment
2IR receiver
3Sensitivity adjustment
4VU meters color adjustment
5A/B amplifier selection
6Microphone activation
7Speakers 1/2 selection
8Pair of speaker outputs 2
9Speaker pair output 1
10Microphone
115V DC power supply via USB-C
12Amplifier input B
13Amplifier input A
Product typeAudio selector switch VU Meter
Inputs2x Speaker terminals
Outputs2x Speaker terminals
Maximum supported power350W @ 4Ω
200W @ 2Ω
Supported amplifier typesAll types (BTL digital amplifier / Class A / Class B / Class D / tube amplifier)
Frequency response30Hz-20kHz
MIC microphone
Remote
Settings saved after shutdown
Power supply5V DC ≥ 2A via USB-C
Dimensions268 x 155 x 75mm
WeightNet: 1.61kg
Gross: 2kg
ColorYellow
Package1x Douk Audio VU3PRO
1x USB-C cable
1x AC adapter
1x Remote control
Très bon
Très bon pour comparer à l'écoute deux amplis ou deux paires d'enceintes. basculement très simple par télécommande, pas de trou ou de perturbation entre les 2 sons. La comparaison est immédiate.
Vu mètres très réussis et très agréables.
This review has been posted for DOUK AUDIO VU3PRO Audio Selector Switch VU Meter Yellow
The Douk Audio VU3PRO is an innovative and comprehensive audio solution combining amplifier switching, speaker selection, and dynamic visual...
