AUDIOPHONICS LPSU25 Linear Regulated Power Supply EMI RFI Filter 220V to 12V 1.25A 25VA
Reference : 11375
75,00 €tax incl.
62,50 € tax excl.
Shipping date: 09-09-2025.
alimentation linéaire 16v régulée audiophile HIFIAudiophile regulated power supply for any Hifi device running on 12V (DAC, digital sources for example).
Here is a regulated and stable linear power supply for any high quality DIY audiophile project. All the necessary technical refinements are incorporated into this dedicated audio power supply.
EIt includes a Hexfet IRF controller of series 34Z driven by low-noise OP Analog-Device and not an integrated circuit. The incorporated EMI RFI filtering ensures a very low noise (ripple) of electrical pollution (- of 30mv).
Thecomponents of this power supply are of first quality with DALE resistors and 4 capacitors of filtering BC of 220μf each. The benefits of a linear quality feed are better readability of the acute medium and a much better cut out.
nsaidsi this regulated linear power solution developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two DC 5.5 / 2.1mm output jacks, this power supply with an extremely stable 25VA transformer even under heavy load will allow you to make the best of audio connected.
As this power supply do not have over current protection, the load should not exceed it's capacity.
Features:
  • Case: 100% Brushed and sanded aluminum
  • Black Anodized
  • Input Voltage: AC 220V
  • Output Voltage / Current:
    • 12V 1.25A  MAX Continuous
    • 12V 2.0A  MAX (5min)
  • Outputs: 2 outputs Jack DC 5.5 / 2.1mm
  • IEC socket
  • Shielded molded anti-vibration transformer 25VA
  • AOP-controlled HEXFET IRF-type controller
  • EMI RFI filter with chokes and film capacitors
Dimensions and weight:
  • 174 x 100 x 51 mm
  • Weight: 0.850kg
  • 1x DC 5.5/2.1mm male/male jack cable with 75cm ferrites supplied
  • Power cable not included
InputIEC C14
OutputJack DC 5.5/2.1mm
Output voltage (V)12.0
Output current (A)1.25
Input voltage (V)230.0
Power SupplyLinear
21 reviews
Nice
It does exactly what an audiophile LPS is supposed to do, and for that price there’s no other choice …
This review has been posted for AUDIOPHONICS LPSU25 Linear Regulated Power Supply EMI RFI Filter 220V to 12V 1.25A 25VA
Transcendée.
Une expérience d’écoute optimale avec une alimentation linéaire de qualité, comme l’Audiophonics 12V, améliore la stabilité du signal de DAC :
• Moins de bruit de fond (baisse du bruit de commutation haute fréquence)
• Meilleure scène sonore (plus de profondeur, de micro-détails)
• Timbres plus naturels
• Grave plus tendu.
contribuant ainsi à une meilleure restitution sonore précise et fluide de mon système hi-fi.
Parfait
Le bourdonnement des hautparleurs est passé de "Wouuuu" à un légé "chhhhhhhhh"
Réduction des pics de fréquence:
50Hz: -18 dB
105Hz: -20 dB
115Hz: -15 dB
Très bon produit
Ce produit est très bien conçu, performant et améliore nettement les performances de mon preamplificateur phono Musical Fidelity V90 LPS, par rapport au petit adaptateur secteur fourni d'origine. Le souffle est diminué, la scène sonore plus large, c'est un plaisir. Je recommande ce produit.
Cordialement.
Jacques
TB qualité, fait parfaitement le job
Achetée pour alimenter le préampli FX-AUDIO Tube01. Une alim classique qui respire la qualité et "assurera" sans doute durant de longues années !
