DOUK AUDIO D2-PRO Linear Power Supply
The Douk Audio D2 PRO is a 12 V linear power supply designed to provide a stable DC voltage to compatible Hi-Fi and digital devices. Its toroidal transformer, LM1085IT regulation and multi-stage filtering allow a maximum power of 35 W to be reached, with a ripple noise below 30 μV at no load.
Reference : 22459
129,00 €tax incl.
107,50 € tax excl.
Douk Audio D2-PRO Linear Power Supply DC Jack 2x 12V 1.25A 30W
Douk Audio D2 PRO: Front view
The Douk Audio D2 PRO is a 12V linear power supply designed to provide a stable DC voltage to compatible Hi-Fi and digital devices. Its toroidal transformer, LM1085IT regulation and multi-stage filtering allow a maximum power of 35W to be reached, with a ripple noise below 30μV at no load.
Thanks to its two parallel DC outputs, the D2 PRO can simultaneously power two components such as a DAC, a preamplifier, a headphone amplifier or a network device. This architecture combines current capacity, interference reduction and passive dissipation, in order to integrate into an audio setup without adding noisy ventilation.
Douk Audio D2 PRO: Dual 12V power supply
The Douk Audio D2 PRO is a linear power supply designed for Douk Audio products, while remaining compatible with many devices operating on 12V, such as DACs, preamplifiers, headphone amplifiers, DDCs, routers, network switches and digital players. Its two parallel DC 5.5 × 2.5mm outputs, compatible with 2.1 to 2.5mm connectors, allow two devices to be powered simultaneously from a single source,  with a stable voltage of up to 1.25A per output and a maximum power of 35W.
Douk Audio D2 PRO: Transformer
Douk Audio D2 PRO: 35W toroidal transformer
The D2 PRO relies on a toroidal transformer specifically sized to improve the efficiency, precision and stability of the power delivered to Hi-Fi components. Regulation is based on a Texas Instruments LM1085IT chip, capable of providing high current while maintaining low electrical background noise, which suits devices subject to significant consumption variations. In addition, the fast rectification circuit ensures more efficient conversion and limits thermal losses, thus contributing to long-term operating stability.
Douk Audio D2 PRO: Filtering and interference reduction
The power supply integrates several filtering stages intended to reduce disturbances present on the mains and on the DC voltage. The EMI suppression circuit attenuates high-frequency interference before conversion and regulation, while the high-capacity matrix filter acts on high- and low-frequency noise. This architecture allows a ripple noise level below 30 μV at no load to be achieved, with a stated reduction down to 28μV thanks to advanced filtering, in order to provide a cleaner DC power supply to audio and digital circuits.
Douk Audio D2 PRO: Noise reduction
Douk Audio D2 PRO: Thermal dissipation and system integration
The enclosure design incorporates multi-segment surface machining, which limits interference while promoting natural heat evacuation. This passive dissipation accompanies regulation and fast rectification without requiring active ventilation, thus maintaining silent operation within a Hi-Fi setup. By powering two devices from a single stabilized source, the D2 PRO can take its place at the heart of a system combining a digital-to-analog converter, a preamplifier, a headphone amplifier or network components.
Technical specifications
Product typeLinear power supply
Outputs2x DC Jack 5.5/2.5 (compatible 2.1)
Output voltage / current12V / ≤2.5A single output (The current is shared between the two outputs)
Output PowerRated: 30W
Max: 35W
Ripple noise28μVrms
Supply voltage110V-120V AC
220V-240V AC
Dimensions115 × 161 × 62mm
Weight1.33kg
Package1x Douk Audio D2 PRO
1x Power cable
1x DC Jack cable
InputIEC C14
OutputJack DC 5.5/2.5mm
Output voltage (V)12.0
Output current (A)2.5
Input voltage (V)120.0
Input voltage (V)230.0
Power SupplyLinear
J’ai branché sur le douk d2 pro un dac audalytic dr70 et un steamer fosi s3 lite (tous deux très bons). Petite précision : la prise dc du dr70 est en 2,1 mm alors que celles du d2 pro sont en 2,5 mm.
L'apport de l'alimentation linéaire du d2 pro est tout à fait remarquable et ce à tous les niveaux et notamment la qualité des timbres et la présence des instruments et des voix. Je ne pourrais pas dire ce qu’elle vaut comparativement à une autre alimentation linéaire, mais, dans ma configuration, je ne regrette pas du tout cet apport qui m'apparaît désormais essentiel si l’on veut optimiser sensiblement l’écoute en streaming.
This review has been posted for DOUK AUDIO D2-PRO Linear Power Supply DC Jack 2x 12V 1.25A 30W
The Douk Audio D2 PRO is a 12 V linear power supply designed to provide a stable DC voltage to compatible Hi-Fi and digital devices. Its toroidal...
