KECES P14 Ultra Low Noise Regulated Linear Power Supply 4 Outputs 5 / 7 / 9 / 12 / 15 / 19 / 24V DC 14A
The Keces P14 is a high-quality regulated linear power supply. This power supply will provide your HiFi audio system with a clean and stable electrical signal. The Keces P14 benefits from a totally analogue design and high-quality components.
By buying this product you get 175 loyalty points
Reference : 17882
1 750,00 €tax incl.
1 458,33 € tax excl.
KECES P14
Ultra Low Noise Regulated Linear Power Supply 4 Outputs 14A
KECES P14 Alimentation Linéaire Régulée Ultra Faible Bruit 4 sorties 14A
The Keces P14 is a high-quality regulated linear power supply. This power supply will provide your HiFi audio system with a clean and stable electrical signal. The Keces P14 benefits from a totally analogue design and high-quality components such as a very powerful toroidal transformer. Each of the 4 output channels has a separate ground. The quality of this power supply's design results in an ultra-low noise signal and eliminates any noise at 50Hz and at maximum load. For this P14 power supply, Keces has also chosen to use Quantum Resonance technology, which enables electromagnetic components to resonate in the same time to improve coherence and synchronisation. It also incorporates OCP protection in the event of overcurrent, and OTP protection in the event of overheating (over temperature protection).
The Keces P14 power supply must be placed in a well-ventilated area. In addition, it must not be positioned above or below any other HiFi equipment.
USB isolator
In addition to these 3 power supply outputs, the Keces P14 has a USB isolator with a USB-B input and a USB-A output (5V 2A). This USB isolator will allow you to enjoy your digital signal sources such as a computer while protecting the signal from noise generated by the source device. The isolator supports PCM sampling rates up to 24bit 96kHz and DSD up to DSD64.
Keces P14 rear panel
1USB-A isolator output
2USB-B isolator input
3ZONE II: DC output 12V / 15V / 19V / 24V 6A
4ZONE III: DC output 5V / 9V 2A
5Output voltage selection ZONE III: 5V/9V
6ZONE I: DC output 5V / 7V / 9V / 12V 4A
7Starting mode selection
8Input/Output 12V trigger Jack 3.5mm
9Power plug IEC C14
10Fuse slot
11Switch on/off
Product typeUltra low-noise regulated linear power supply
Input voltage (switchable)AC 110V-120V 60Hz (T3A Fuse)
AC 220V-240V 50Hz (T1.5A Fuse)
Output voltage and currentZone I: 5V / 7V / 9V / 12V, 4A
Zone II: 12V / 15V / 19V / 24V, 6A
Zone III: 5V / 9V, 2A
Zone IV: USB 5V, 2A
Ripple noise< 100µV at full power
< 10µV at 60% load
USB isolatorSupport low and full speed data rate for 1.5Mbps and 12Mbps
Body materialAluminum
Power consumptionStandby: 0.5W
Maximum: 350W
Dimensions 300*279*66mm
Weight7kg
Package1* Keces P14
1* Power cable
2* Jack DC 5.5/2.5mm cable
1* Jack 3.5mm cable
InputIEC C14
InputJack 3.5mm
OutputUSB
OutputJack DC 5.5/2.5mm
OutputJack 3.5mm
Output voltage (V)12.0
Output voltage (V)15.0
Output voltage (V)9.0
Output voltage (V)5.0
Output voltage (V)19.0
Output voltage (V)7.0
Output voltage (V)24.0
Output current (A)6.0
Output current (A)2.0
Output current (A)4.0
Input voltage (V)115.0
Input voltage (V)230.0
Power SupplyRegulated Linear Power Supply
The Keces P14 is a high-quality regulated linear power supply. This power supply will provide your HiFi audio system with a clean and stable...
