No featrued products
Regulated linear power supply 12 / 15 / 16V + 12 / 15 / 16V 2A
The Keces P3 is a high quality regulated linear power supply that will provide your high fidelity audio system with a clean electrical signal for quality playback. The power supply offers a careful design with a high quality toroidal transformer and a separate ground for each rail. This internal design provides an ultra-low noise signal and cancels all "buzzing" at 50Hz and maximum load. The power supply also includes protection against exceeding the maximum operating temperature (Over Temperature Protection). All components are placed in a robust and stylish black brushed Aluminium case. The brand logo is stamped directly into the Aluminium on the power supply cover.
If the Keces P3 is particularly interesting it is also because it offers two adjustable DC outputs.Thus, the first output can be set to 12V, 15V or 16V, and the second as well. A switch on each output allows you to simply select the desired voltage. On the current side, each output provides 2A (Maximum 3A at peak). The input voltage is also selectable (230V or 115V AC) via a switch under the device, to adapt to the current supplied by your mains sockets.
| Specifications | |
| Product type | Regulated linear power supply |
| Input voltage (Switchable) | AC 110V-120V 60Hz AC 220V-240V 50Hz |
| Output voltage | Output 1 : DC 12V / 15V / 16V Output 2 : 12V / 15V / 16V |
| Output connector | Jack DC 5.5/2.5mm |
| Consumption | 120W (Full output load) |
| Housing | Brushed Aluminium 3mm |
| Weight | 3.5kg |
| Color | Black |
| Package | 1x Keces P3 1x Power cable Schuko / IEC 2x Jack DC 5.5/2.5mm to Jack DC 5.5/2.1mm Cable 2x Jack DC Adapters 5.5/2.1mm to 5.5/2.5mm |
| Input | IEC C14 |
| Output | Jack DC 5.5/2.5mm |
| Color | Black |
| Output voltage (V) | 12.0 |
| Output voltage (V) | 15.0 |
| Output voltage (V) | 16.0 |
| Output current (A) | 2.0 |
| Input voltage (V) | 230.0 |
| Input voltage (V) | 120.0 |
| Power Supply | Linear |
