Hervorragendes LPS zum sehr guten Preis, zuverlässig verpackt und schnell geliefert.
Vielen, herzlichen Dank an das ganze AUDIOPHONICS Team, ihr seid die besten
Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio, and it will work perfectly with your HiFi devices operating at 5V (DAC, digital source...).
This power supply includes a Talema transformer coupled with an AOP 177 for even greater voltage stabilization and control. EMI filtering is also included to eliminate interference created by alternating current (AC). Furthermore, a set of three CLC filters positioned at the input and output of the power supply ensure efficient filtering and guarantee a noise-free signal. Last but not least, a bridge rectifier ensures reliable current stabilization, even during prolonged use. The result is a stable output signal with a noise level not exceeding 200uV when used to its full capacity.
The power supply features an aluminum alloy case for efficient heat dissipation, a DC 5.5/2.1mm jack output and a USB-A output. Finally, you can adjust the output voltage on the back of the device by ±0.5V if required.
| Specifications | |
| Input voltage | 220-240V |
| Output Voltage / current | 5V 3A Max 5V 2A Continuous |
| Outputs | Jack DC 5.5/2.1mm USB-A 5V |
| Input | IEC |
| General | |
| Case material | Aluminium alloy |
| Dimensions | 110 x 155 x 63mm |
| Weight | 1.114kg |
| Package | 1x LHY AUDIO LPS25VA 1x DC 5.5/2.1mm male/male jack cable 80cm 1x power supply cable |
| Input | IEC C14 |
| Output | USB |
| Output | Jack DC 5.5/2.1mm |
| Color | Black |
| Output voltage (V) | 5.0 |
| Output current (A) | 2.0 |
| Input voltage (V) | 220.0 |
| Power Supply | Regulated Linear Power Supply |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Frank D.
Luca C.
Paul G.
