Switched Mode Power Supply 100-240V AC to 48V 7A DC
This AC adapter takes an input voltage of 100-240VAC to output 48VDC 7.3A (350W). The components are integrated in a robust aluminum chassis that dissipates the heat generated by the components. The power supply ensures a very low ripple to provide a clean electrical signal to your HiFi devices.
4.8 / 5
Reference : 14749
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 01-12-2026.
Adaptateur Secteur Alimentation
100-240V AC vers 48V 7A DC
Adaptateur Secteur Alimentation 100-240VAC vers 48V 7A DC
This AC adapter takes an input voltage of 100-240VAC to output 48VDC 7.3A (350W). The components are integrated in a robust aluminum chassis that dissipates the heat generated by the components. The power supply ensures a very low ripple to provide a clean electrical signal to your HiFi devices. The circuit also integrates protections against overcurrents, overvoltages, thermal overshoot and short circuits. The AC input is on an IEC C14 connector and the output on a GX16 connector.
Please note that there is no standard for polarities on GX16 connectors. The - and + polarities may be inverted, depending on the manufacturer, and may not be compatible with certain devices. Using a non-compatible cable can result in the destruction of your equipment.
The cable to be used with this power supply must have the following polarity. Check that it is compatible with your equipment before use:
Polarité de câblage
Product typeSwitched mode power supply
Input1x IEC C14
Output1x GX16
Input voltage100-240VAC 50/60Hz
Output voltage48VDC 7.3A (adjustable from 41.5 to 53VDC)
Voltage precision±5%
Package1x Switched mode power supply
1x Power cable
1x GX16 to Jack DC 5.5/2.5mm (5.5/2.1mm compatible) cable
Dimensions102 x 208 x 50mm
Housing materialBrushed aluminium
Black front panel
InputIEC C14
OutputGX12
ColorSilver
Output voltage (V)48.0
Output current (A)7.0
Input voltage (V)130.0
Input voltage (V)230.0
Input voltage (V)210.0
Input voltage (V)240.0
Input voltage (V)110.0
Input voltage (V)120.0
Input voltage (V)200.0
Input voltage (V)220.0
Input voltage (V)100.0
Power SupplySMPS
8 reviews
Quality build!
Nice quality build PSU with good connectors. Packed nicely and shipped fast!
This review has been posted for Switched Mode Power Supply 100-240V AC to 48V 7A DC
Très bien avec un FOSI BT20A Pro
Avec mon FOSI Audio livré à l’origine avec une alimentation 32v, l’apport de cette alimentation 48v est bénéfique. Plus que la puissance , elle apporte de la matière et de la vivacité.
L’appareil paraît solide.
Un bon achat.
Compatible avec le Aiyima A07
Très bon adaptateur d'alimentation qui fonctionne bien avec l'amplificateur Aiyima A07.
Il inspire confiance comparé à l'adaptateur générique livré avec l'amplificateur Aiyima.
Merci Audiophonics!
Bien mais…
Résultats incroyables sur Aiyima A007 mais produits reçu abîmé sur un coin !
De plus l’alimentation était juste entourée de film alimentaire ! Même pas de carton de marque, juste calé dans un carton d’expédition…
Comme le colis était intact je suppose que l’article a été abîmé (chute avant expédition) avant l’envoi. Pas sérieux !
Du coup j’hésite à commander les 2 alims supplémentaires dont j’ai besoins chez Audiophinics… dommage.
Bonjour,
Nous sommes navré que vous ayez reçu l'alimentation abimée.
Vous pouvez sans problème contacter notre SAV via votre espace client afin d'obtenir une unité intacte.
Parfait
Livraison au top, alimentation qui fonctionne parfaitement !
This AC adapter takes an input voltage of 100-240VAC to output 48VDC 7.3A (350W). The components are integrated in a robust aluminum chassis that...
